LibreDrive for Pioneer drives
#1081 Post by Billycar11 » Fri Oct 18, 2024 8:08 am
CCRider wrote: Fri Oct 18, 2024 8:01 am I am new to this so please excuse me for my ignorance.
I recently purchased a Pioneer BDR-S13J-X on Amazon and to my surprise it wasn't able to rip any of my 4k BD.
Basically it isn't Libre enabled.
Can someone kindly guide me to where I can get the old firmware from and the tool to flash my drive.
I'm 67 years young and have rudimentary tech knowledge.
sadly there is no way to downgrade it.
you have to Buy a pioneer from a seller in your region with old fw see below if you in the usa or see seller section for other regions
CCRider
#1082 Post by CCRider » Fri Oct 18, 2024 9:10 am
Thankyou for the prompt reply Billycar11.
I will do as you suggested. :)
SeaLight
#1083 Post by SeaLight » Fri Oct 18, 2024 12:55 pm
I just bought a flashed drive from Billy because nothing that I found was able to work.
tiefling
#1084 Post by tiefling » Mon Oct 21, 2024 2:44 pm
I have a PIONEER BDR-X13
I see the following:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision 1.03
Serial Number: redacted
Firmware date: 2022-12-12
Highest AACS version: 81
Drive platform: Pioneer RS9400
Firmware version: ID56
How do I / can I "enable" this?
#1085 Post by Coopervid » Mon Oct 21, 2024 3:06 pm
tiefling wrote: Mon Oct 21, 2024 2:44 pm I have a PIONEER BDR-X13
Revision 1.03
You can't. Firmwares starting Dec. 2022 can't be enabled anymore.
Blyth
#1086 Post by Blyth » Tue Oct 22, 2024 10:41 pm
Would mine be able to be flashed to rip Ultra HD discs?
I hops so as I have just bought this one :|
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 39
Drive platform: RS8511
Firmware version: 1.14
mike_ranger
#1087 Post by mike_ranger » Wed Oct 23, 2024 8:30 am
Here is my info....
Revision: 1.14
Serial number: ALDL438773WL
Highest AACS version: 31
Thanks in advance for the UHD support
#1088 Post by Coopervid » Wed Oct 23, 2024 9:07 am
Blyth wrote: Tue Oct 22, 2024 10:41 pm Would mine be able to be flashed to rip Ultra HD discs?
Revision: 1.14
PM is coming.
#1089 Post by Coopervid » Wed Oct 23, 2024 9:09 am
mike_ranger wrote: Wed Oct 23, 2024 8:30 am Here is my info....
Revision: 1.14
PM sent.
bricomp
#1090 Post by bricomp » Wed Oct 23, 2024 1:11 pm
Good morning - looking for LibreDrive supported firmware, currently have a BDR-212U with firmware 1.0 (nice and new).
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: [redacted]
Firmware date: 2019-01-10
Highest AACS version: 61
Drive platform: Pioneer RS8F01
Firmware version: ID83
Thanks in advance.
Kostja_V
#1091 Post by Kostja_V » Wed Oct 23, 2024 5:25 pm
Hello. Any chances for UHD support on:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Firmware date: 2013-09-10
Drive platform: RS8600
Firmware version: E401/ID44
#1092 Post by Coopervid » Wed Oct 23, 2024 6:16 pm
bricomp wrote: Wed Oct 23, 2024 1:11 pm Good morning - looking for LibreDrive supported firmware, currently have a BDR-212U with firmware 1.0 (nice and new).
Revision: 1.00
Thanks in advance.
PM sent.
#1093 Post by Coopervid » Wed Oct 23, 2024 6:19 pm
Kostja_V wrote: Wed Oct 23, 2024 5:25 pm Hello. Any chances for UHD support on:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
PM is on its way.
Kostja_V
#1094 Post by Kostja_V » Thu Oct 24, 2024 12:30 pm
Coopervid wrote: Wed Oct 23, 2024 6:19 pm PM is on its way.
Thank you very much. Worked like a charm, just in few clicks.
Can't reply you in private, because PM are blocked for me.
ItsRawberry
#1095 Post by ItsRawberry » Thu Oct 24, 2024 1:48 pm
I did a quick search but didn't see this drive info come up for support. Here's my details:
OS device name: K:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 78
Firmware version: ID05
I currently cannot rip UHDs - any chance to get this drive supported?
