UHD dump sending, attachment or googledrive?
ellenia
#1 Post by ellenia » Mon Oct 07, 2024 4:22 am
If Makemkv failed decrypting a UHD and created a dump file, which is the perferable way to send dump file, attchment or googledrive?
I used to send with attachment, but I worry that the mailing system might keep makemkv team from recieving the dump (cannot confirm though), will googledrive be a better option?
I'm using gmail btw.
Re: UHD dump sending, attachment or googledrive?
#2 Post by dcoke22 » Mon Oct 07, 2024 3:18 pm
I think either works, but most people send the dump as an email attachment.
JFIF2
#3 Post by JFIF2 » Mon Oct 21, 2024 12:50 pm
For most dump files, especially larger UHD dump files, using Google Drive would be more suitable. You can generate a shared link after uploading the file and send it to the recipient, which can avoid the issue of attachment size restrictions.
