Pioneer BDR-UD03 UHD possibility
Myral
Re: Pioneer BDR-UD03 UHD possibility
Post by Myral » Sat Oct 19, 2024 5:36 pm
Hi, I recently bought an external Verbatim drive model BIAA / 43890 which I thought would support all DVDs including UHD...to my surprise, it does not support UHD. My research for a solution on the net, brought me to this forum, which is great by the way. I would greatly appreciate if you could find the time to PM me the solution you have been providing others in this thread. Thank you in advance.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 16
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Sat Oct 19, 2024 7:19 pm
Myral wrote: Sat Oct 19, 2024 5:36 pm Hi, I recently bought an external Verbatim drive model BIAA / 43890 which I thought would support all DVDs including UHD...to my surprise, it does not support UHD. My research for a solution on the net, brought me to this forum, which is great by the way. I would greatly appreciate if you could find the time to PM me the solution you have been providing others in this thread. Thank you in advance.
OS device name: G:
Revision: 1.14
PM sent.
Myral
Post by Myral » Sat Oct 19, 2024 10:41 pm
Thank you very much, I will try the fix tomorrow. :)
FidgetyZookeeper
Post by FidgetyZookeeper » Sun Oct 20, 2024 12:40 am
Coopervid wrote: Sat Oct 19, 2024 9:44 am
FidgetyZookeeper wrote: Sat Oct 19, 2024 12:40 am Mind if I also request the Pioneer firmware fix for UHD disc reading? (Sorry I know there have been a lot of these)
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 1.14
Serial number: <>
Highest AACS version: 68
PM sent.
Many thanks!!
Gribnik81
Post by Gribnik81 » Mon Oct 21, 2024 4:10 pm
Hello, please tell me where I can find firmware 1.14. Thank you
Post by Coopervid » Mon Oct 21, 2024 5:22 pm
Gribnik81 wrote: Mon Oct 21, 2024 4:10 pm Hello, please tell me where I can find firmware 1.14. Thank you
Post your Makemkv info with "Drive platform".
Gribnik81
Post by Gribnik81 » Mon Oct 21, 2024 6:19 pm
Current profile: CD-ROM
Revision: 1.10
Serial number:redacted
Firmware date: 2017-04-18
Firmware version: 1.10
Post by Coopervid » Mon Oct 21, 2024 7:39 pm
Gribnik81 wrote: Mon Oct 21, 2024 6:19 pm Drive Information
Revision: 1.10
PM sent.
Gribnik81
Post by Gribnik81 » Mon Oct 21, 2024 9:05 pm
Thank you very much!!! Everything worked out. I don't even know what I would do without you. Thank you for being here.
mike_ranger
Post by mike_ranger » Tue Oct 22, 2024 10:07 am
Sorry… did not get the PM yet… many thanks :)
barok
Post by barok » Tue Oct 22, 2024 5:02 pm
Hi. I have the same problem. I can't load verbatim UHD discs on the drive. The driver is a Pioneer UD03. Thank you for your help.
Post by Coopervid » Tue Oct 22, 2024 5:23 pm
mike_ranger wrote: Fri Oct 18, 2024 12:47 pm Hello
The drive cannot read UHD discs.
I would be very happy about a PM.
Thanks, Mikel
Post your Makemkv info.
Post by Coopervid » Tue Oct 22, 2024 5:24 pm
barok wrote: Tue Oct 22, 2024 5:02 pm Hi. I have the same problem. I can't load verbatim UHD discs on the drive. The driver is a Pioneer UD03. Thank you for your help.
selten
Post by selten » Tue Oct 22, 2024 10:55 pm
Could you please also provide me with the firmware?
Drive informatie
Naam OS-apparaat: D:
Fabrikant: PIONEER
Revisie: 1.14
Serienummer: [redacted]
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
Highest AACS version: 72
Geen disc aanwezig
barok
Post by barok » Tue Oct 22, 2024 10:57 pm
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Firmware-Datum: 2020-06-15
Highest AACS version: 81
Disk-Informationen
Label: WANTED_G51
Zeitstempel: 2008-09-26 17:29:50
Schutz: AACS v8
Datenkapazität: 43.54 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
