Greetings! Great website, a lot to read.
Drive had firmware 1.0, downloaded the current version 1.02 from Vinpower Digital.
If I enable LibreDrive, will that affect the drive's error algorithms?
If I enable LibreDrive, will I be able to re-flash the Vinpower 1.02 firmware?
How do I enable LibreDrive? Any help will be greatly appreciated!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 68
Firmware version: ID06
Best Regards,
H2O#skier
Older BDR-212V
Re: Older BDR-212V
Your drive can be flashed to read UHDs if you want this. No disadvatages, only advantages. And it can be flashed back to Vinpower software.H2O#skier wrote: Thu Oct 17, 2024 1:29 am Greetings! Great website, a lot to read.
OS device name: E:
Revision: 1.02
Best Regards,
H2O#skier
jrinehart76
Re: Older BDR-212V
What's the MFD date on your drive?H2O#skier wrote: Thu Oct 17, 2024 1:29 am Greetings! Great website, a lot to read.
OS device name: E:
Revision: 1.02
Best Regards,
H2O#skier
