The Office Season 8 Issues
ffbacklash
Post by ffbacklash »
I've been having issues with my copy of The Office Season 8 on bluray. I've already exchanged my copy once, and the problem persists, so its not the disc. When I first insert the disc inside the drive, before I even tell MakeMKV to scan it, it takes a long time to be read, and I get these errors.
MakeMKV v1.14.4 win(x64-release) started
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.03' at offset '22732865536'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.03' at offset '22732929024'
Then when scanning the disc, I get all of this.
Using LibreDrive mode (v05 id=5E80BBEE7E45)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '721446912'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '5903210496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '2548961280'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '5335744512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '1257123840'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '1757681664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '1458739200'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '3616278528'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '1768390656'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '5541832704'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '0'
Title #00800.mpls was skipped
File 00801.mpls was added as title #0
File 00802.mpls was added as title #1
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '0'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '0'
Title #00803.mpls was skipped
File 00804.mpls was added as title #2
File 00805.mpls was added as title #3
File 00020.mpls was added as title #4
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00312.m2ts' at offset '0'
Title #00300.mpls was skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00021.m2ts was added as title #5
File 00022.m2ts was added as title #6
File 00800.m2ts was added as title #7
Title #00301.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00803.m2ts was skipped
Title #00105.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00303.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00305.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00307.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00302.m2ts' at offset '0'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00302.m2ts' at offset '0'
Title #00302.m2ts was skipped
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00304.m2ts' at offset '0'
Title #00304.m2ts was skipped
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00306.m2ts' at offset '0'
Title #00306.m2ts was skipped
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00308.m2ts' at offset '0'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00308.m2ts' at offset '0'
Title #00308.m2ts was skipped
Title #00310.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00312.m2ts was skipped
Encountered 164 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Errors aren't consistent, and I can confirm the disc works perfectly in a bluray player. Is this because the disc is double sided? (DVD on one side, BluRay on the other)
Re: The Office Season 8 Issues
MakeMKV cannot correct hardware errors:
The usual cause of such things is when the drive is trying TOO hard to read a sector of the disk, and fails to respond to the operating system in time. The OS says, "Oh, the drive has disappeared!"
Cleaning the disk fixes the majority of such errors, unless the disk itself is flawed.
dockingbay94
Post by dockingbay94 »
I recently purchased this set used. I am having similar problems. On my MAC, the disk reads "forever" and never shows up in Finder. If I try to manually eject the disk or power off the external optical drive, the OS crashes!
I tried these disks on my Windows 10 laptop (different optical drive) and the disk never shows up in explorer.
However, they made these disks, they seem unreadable on non-Bluray players.
thejm
Post by thejm »
I am having the same issues with the below errors.
MakeMKV v1.15.1 win(x64-release) started
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH14NS40 1.02' at offset '22732865536'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH14NS40 1.02' at offset '22732929024'
udf: node fe/efe failed!
Using LibreDrive mode (v06.2 id=10F16E86E12A)
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
Error 'OS error - The I/O device reported an I/O error' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '0'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '0'
I have both a WH14NS40 running 1.02 and a WH6NS40 running 1.04. Both of the drives exhibit the same behavior and errors.
Has anyone come up with a solution?
thejm
Post by thejm »
Just wanted to add to my last post. I purchased The Office Season 8 from Amazon https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
This set consists of double sided disks with blu-ray being on one side of the disk and dvd being on the other. I read several of the reviews and saw several people complaining about the disks not working.
See below
Screen Shot 2020-06-25 at 10.06.18 AM.png (81.61 KiB) Viewed 34558 times
I though maybe it was an issue with a security feature that the disks had that MakeMKV couldnt overcome but im starting to think it might be poor quality disks. I am going to try to put my disks in my old standalone blu ray player tonight and see if they work there. I will report back with my results but can confirm the disks don't play in Windows 10 on 2 different Blu-ray drives.
andcbii
Post by andcbii »
Did you get this to work? 1/2 the time windows doesn't even see these discs.
fliptcb
Post by fliptcb »
Found a small workaround by taping the DVD side with gaffer tape, then trimming around the edges thus making the discs less transparent. So far ripping individual episodes rather than all chapters together has worked for me. My guess is that the laser is picking up too much information and confusing the drive from the DVD side. Using an BD-RE ASUS BW-16D1HT 3.02. Will update if fully successful.
Angryman
Post by Angryman »
Here in the UK the American Office version was well ahead of us here so for the final seasons (6 onwards) we were getting the US version off ebay. At least 2 seasons (including season 8 ) were Pirate copies, damn good ones with all the packaging and printed discs etc , but they were pirate. The ripped file sizes were much smaller that the other legit season episodes. I seem to remember that was more difficult than normal to rip. To summarise, the US version of The Office was pirated a lot, and there are a ton of fakes out there and almost impossible to tell from the real thing.
DC-2187
Post by DC-2187 »
fliptcb wrote: Mon Aug 10, 2020 3:42 am Found a small workaround by taping the DVD side with gaffer tape, then trimming around the edges thus making the discs less transparent. So far ripping individual episodes rather than all chapters together has worked for me. My guess is that the laser is picking up too much information and confusing the drive from the DVD side. Using an BD-RE ASUS BW-16D1HT 3.02. Will update if fully successful.
Has this solution worked for you. I usually always rip individual episodes so would this help me get them ripped?
fliptcb
Post by fliptcb »
I made it through all but disk 3 painstakingly. I kept spitting the disc out, ripping, then repeating with multiple attempts. I found more success selecting a single episode then ripping rather than hitting all 4-6 episodes at once, if that makes sense. Also for what it’s worth, lining the disc in drawer/shelf paper worked much better than the thicker tape as I used before. There were times when it was trying to read for a good 5-10 minutes before any disc info loaded.
DC-2187
Post by DC-2187 »
fliptcb wrote: Sun Aug 16, 2020 11:48 pm I made it through all but disk 3 painstakingly. I kept spitting the disc out, ripping, then repeating with multiple attempts. I found more success selecting a single episode then ripping rather than hitting all 4-6 episodes at once, if that makes sense. Also for what it’s worth, lining the disc in drawer/shelf paper worked much better than the thicker tape as I used before. There were times when it was trying to read for a good 5-10 minutes before any disc info loaded.
okay good to know. i might have to try this out and see how it works. if i would to use the drawer/shelf paper would i just use tape to put it on? is there something i should use here?
fliptcb
Post by fliptcb »
I used drawer liner that was already sticky. Wallpaper would work too. A thin giant sticker essentially.
DC-2187
Post by DC-2187 »
fliptcb wrote: Mon Aug 17, 2020 2:12 am I used drawer liner that was already sticky. Wallpaper would work too. A thin giant sticker essentially.
I didn't have any sucess with this method however my order of the office complete series on blu-ray came in this morning. I hope this will have a season 8 that will make it alot easier to use on makemkv.
thejm
Post by thejm »
andcbii wrote: Fri Jul 31, 2020 1:38 am Did you get this to work? 1/2 the time windows doesn't even see these discs.
I ended up returning the disks to amazon and getting the season digitally from my brother.
anthone
Post by anthone »
If anyone is still having issues with double sided discs like these, I managed to get most of The Office Season 8 ripped using the blu ray side. To start, disc 3 and 5 were no problem, DVD side was no problem. Disc 1 would never work on my WH16NS60 with 1.02 firmware. These steps might still work with other drives though. What ended up working with disc 1,2, and 4 was an external drive I didn't even get for ripping movies, and even it was still troublesome. This is the drive that worked: https://a.co/d/8Wu7nXg
The steps that worked for me:
1. Unplug the drive - no disc inserted
2. Restart the computer
3. Plug drive back in
4. Insert disc and let it load for a moment
5. Open Makemkv and everything works like usual
- It took about 4 hours to rip one disc but it finally worked
- Repeat the same process for each disc. For some reason it would never recognize subsequent discs.
