Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
mookieman
Just had this delivered, it reads BluRay's no problem but when I insert any UHD Discs it does not read them, it just says "No Disc Inserted". I was using an Asus 5.25 internal drive until it decided to completely shred a UHD copy of Dunkirk on me. The UHD's I tested, Arrival and Blade Runner have already been ripped with the Asus drive before it went doolally.
Here's the MKV Info for the drive in question.
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ALDL438296WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
The 43890 (BDR-UD03) is a blu-ray drive, not a UHD drive. The 43888 is the UHD model (containing a BDR-UD04)mookieman wrote: Sat Jan 13, 2024 9:46 pm Just had this delivered, it reads BluRay's no problem but when I insert any UHD Discs it does not read them, it just says "No Disc Inserted". I was using an Asus 5.25 internal drive until it decided to completely shred a UHD copy of Dunkirk on me. The UHD's I tested, Arrival and Blade Runner have already been ripped with the Asus drive before it went doolally.
Revision: 1.14
mookieman
Ah understood, so there's no way to get this drive to read UHD Discs never mind decrypt them. I think I'll send it back and order one of the recommended ones from your site.
You can email me for a automated flasher to this drive to make it read UHD discs
mookieman
Thanks, just sent you an email.
jabie5
@ Billcar11,
i have just bought the same drive. Then i found this website, so you are saying this drive can be flashed to read UHD discs. If this is the case can you help.
TIA
jabie5
TIA
jabie5
zittrig
I've a 43890 and the original Verbatim firmware flasher for the 43888 1.14. Originaly I wanted to reflash my 43888 cause of the BD-read freeze error but my mind goes on....
Is there any way to get the 43890 flashed with it? By execute an error occurs that the target is not found.
No. Read your PM.zittrig wrote: Fri Oct 18, 2024 4:46 pm Hi,
zittrig
Great, thank you very much.
I've answered with PM but the message is hanging around in the Outbox, it's not sent.
It was sent. It needs to be read. Until then it's in the outbox.zittrig wrote: Fri Oct 18, 2024 5:26 pm Great, thank you very much.
rosti
Hey guys, same problem here - I have bought recently Verbatim 43890 (BD-RW BDR-UD03 / FW: BDR-US03 1.14)
Is it possible to make it work with UHDs?
Read your PM.rosti wrote: Mon Dec 09, 2024 12:03 pm Hey guys, same problem here - I have bought recently Verbatim 43890 (BD-RW BDR-UD03 / FW: BDR-US03 1.14)
rosti
Coopervid, thank you very much for the message
bobraptors
Hi everyone, I just found this thread online, and I'm looking to flash my newly purchased Verbatim 43890 to support UHD discs.
- Can someone please point me to the flashing the FW & instructions
Any drawbacks after flashing
PM sent.bobraptors wrote: Fri Dec 27, 2024 2:26 am Hi everyone, I just found this thread online, and I'm looking to flash my newly purchased Verbatim 43890 to support UHD discs.
Greatly appreciated
