PM sent.newtbludger wrote: Wed Oct 16, 2024 10:56 pm I just received my Pioneer 212v drive. Any help on getting up and running with UHD ripping is greatly appreciated![]()
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Link246
Thank you for the quick response.Coopervid wrote: Tue Oct 15, 2024 9:35 pmVerbatim 43888 external or Vinpower 212V internal. Vinpower needs to be flashed. The Verbatim works right away.Link246 wrote: Tue Oct 15, 2024 7:19 pm Hi,
I have a LG BH16NS55 (Firmware 1.02) which is unreliable.
What is the best drive available in Germany, that can rip UHDs?
I purchased the Vinpower 212V and received it today.
Can you please let me know where I can find a reliable instruction for flashing the drive?
RobertMoo
I followed your instructions and everything worked out great. Thanks cooper!
PM is coming.Link246 wrote: Fri Oct 18, 2024 10:30 amThank you for the quick response.Coopervid wrote: Tue Oct 15, 2024 9:35 pmVerbatim 43888 external or Vinpower 212V internal. Vinpower needs to be flashed. The Verbatim works right away.Link246 wrote: Tue Oct 15, 2024 7:19 pm Hi,
sally
Any hint for Germany as I'm on the hunt for a new drive? Czech Republic or Luxembourg or Switzerland would also somehow be ok, I'm often enough over there and things aren't sooooo urgent...
See what was recommended to Link246.sally wrote: Fri Oct 18, 2024 10:50 pm Any hint for Germany as I'm on the hunt for a new drive? Czech Republic or Luxembourg or Switzerland would also somehow be ok, I'm often enough over there and things aren't sooooo urgent...
jrinehart76
Just received the 212v as well. Appreciate the assist in flashing if possible
Check your PM.jrinehart76 wrote: Sat Oct 19, 2024 9:54 pm Just received the 212v as well. Appreciate the assist in flashing if possible
Quine
I also recently purchased a BDR-212V and would appreciate a PM as to making it capable of reading UHD Blu-rays. Thank you.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number: ████████████
Firmware date: 2020-08-07
Bus encryption flags: 13
Highest AACS version: 62
Drive platform: RS8F00
Firmware version: 1.00/ID06
Unrestricted read speed: Yes-
jrinehart76
Much appreciated Coopervid!Coopervid wrote: Sun Oct 20, 2024 10:43 amCheck your PM.jrinehart76 wrote: Sat Oct 19, 2024 9:54 pm Just received the 212v as well. Appreciate the assist in flashing if possible
N00bs
Hello everyone,
someone from Canada made a purchase that is reliable and constant with MKV ?
PM sent.Quine wrote: Sun Oct 20, 2024 10:58 am I also recently purchased a BDR-212V and would appreciate a PM as to making it capable of reading UHD Blu-rays. Thank you.
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.00 Serial number: ████████████ Firmware date: 2020-08-07 Bus encryption flags: 13 Highest AACS version: 62 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.00/ID06 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
equip82
@Coopervid
I have also purchased the Vinpower BDR-212V from Amazon Germany:
https://www.amazon.de/Vinpower-Digital- ... r=8-2&th=1
Can I please also get the instructions for the flasher?
Sure. Coming.equip82 wrote: Tue Oct 22, 2024 9:57 am @Coopervid
Quine
Thank you very much.
