LibreDrive for Pioneer drives
CCRider wrote: Fri Oct 18, 2024 8:01 am I am new to this so please excuse me for my ignorance.
I recently purchased a Pioneer BDR-S13J-X on Amazon and to my surprise it wasn't able to rip any of my 4k BD.
Basically it isn't Libre enabled.
Can someone kindly guide me to where I can get the old firmware from and the tool to flash my drive.
I'm 67 years young and have rudimentary tech knowledge.
sadly there is no way to downgrade it.
you have to Buy a pioneer from a seller in your region with old fw see below if you in the usa or see seller section for other regions
CCRider
Post by CCRider »
Thankyou for the prompt reply Billycar11.
I will do as you suggested. :)
SeaLight
Post by SeaLight »
I just bought a flashed drive from Billy because nothing that I found was able to work.
tiefling
Post by tiefling »
I have a PIONEER BDR-X13
I see the following:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision 1.03
Serial Number: redacted
Firmware date: 2022-12-12
Highest AACS version: 81
Drive platform: Pioneer RS9400
Firmware version: ID56
How do I / can I "enable" this?
tiefling wrote: Mon Oct 21, 2024 2:44 pm I have a PIONEER BDR-X13
Revision 1.03
You can't. Firmwares starting Dec. 2022 can't be enabled anymore.
Blyth
Post by Blyth »
Would mine be able to be flashed to rip Ultra HD discs?
I hops so as I have just bought this one :|
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 39
Drive platform: RS8511
Firmware version: 1.14
mike_ranger
Post by mike_ranger »
Here is my info....
Revision: 1.14
Serial number: ALDL438773WL
Highest AACS version: 31
Thanks in advance for the UHD support
Blyth wrote: Tue Oct 22, 2024 10:41 pm Would mine be able to be flashed to rip Ultra HD discs?
Revision: 1.14
PM is coming.
mike_ranger wrote: Wed Oct 23, 2024 8:30 am Here is my info....
Revision: 1.14
PM sent.
bricomp
Post by bricomp »
Good morning - looking for LibreDrive supported firmware, currently have a BDR-212U with firmware 1.0 (nice and new).
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: [redacted]
Firmware date: 2019-01-10
Highest AACS version: 61
Drive platform: Pioneer RS8F01
Firmware version: ID83
Thanks in advance.
Kostja_V
Post by Kostja_V »
Hello. Any chances for UHD support on:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Firmware date: 2013-09-10
Drive platform: RS8600
Firmware version: E401/ID44
bricomp wrote: Wed Oct 23, 2024 1:11 pm Good morning - looking for LibreDrive supported firmware, currently have a BDR-212U with firmware 1.0 (nice and new).
Revision: 1.00
Thanks in advance.
PM sent.
Kostja_V wrote: Wed Oct 23, 2024 5:25 pm Hello. Any chances for UHD support on:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
PM is on its way.
Kostja_V
Post by Kostja_V »
Coopervid wrote: Wed Oct 23, 2024 6:19 pm PM is on its way.
Thank you very much. Worked like a charm, just in few clicks.
Can't reply you in private, because PM are blocked for me.
ItsRawberry
Post by ItsRawberry »
I did a quick search but didn't see this drive info come up for support. Here's my details:
OS device name: K:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 78
Firmware version: ID05
I currently cannot rip UHDs - any chance to get this drive supported?
