PIONEER BDR-XS07TS - how to flash
Mattirvine
Post by Mattirvine » Thu Jun 27, 2024 3:36 pm
hi there
currently looking at a pioneer PIONEER BDR-XS07TS looking to flash it.
is there anything I need to look out for if purchasing it?
does the model I buy need to be a of a specific firmware? how would I flash it once bought?
Re: PIONEER BDR-XS07TS - how to flash
Post by dcoke22 » Thu Jun 27, 2024 3:50 pm
Mattirvine
Post by Mattirvine » Thu Jun 27, 2024 4:01 pm
dcoke22 wrote: Thu Jun 27, 2024 3:50 pm Pioneer firmware update February 2023
What does this mean? if the drive is manufactured during this period is it unable to be flashed?
Post by dcoke22 » Thu Jun 27, 2024 10:38 pm
Yes. If the firmware is too new on pretty much any Pioneer drive, it can't be made to work with LibreDrive. It can work for regular blu-rays and DVDs, but not 4K UHDs.
A Pioneer BDR-XS07TS doesn't look it supports UHD by default. If the firmware is old enough, I do not know if it can be made to read UHDs. That would be a question for Billycar11.
Probably the best way to get a Pioneer drive that'll work with UHDs is to get one from a seller in your region.
Post by Billycar11 » Thu Jun 27, 2024 11:11 pm
it can be crossflashed if the fw is from before 12/22 after that nothing can be done
that may or may not change we dont know
doctorvimto
Post by doctorvimto » Fri Oct 18, 2024 12:32 am
Hi
i got one of those BDR-XS07TS drives back in march for macos. thing is i may have used a flash tool for mac. old habit from pc days when i load any disc, it just reads a second them a crunch sound.. i suspect it has a issue, or it may have been knocked/bumped.
I had been looking for a tool to crossflash the firmware, if still possible, but no idea where to acquire one, or how to use it.
Post by Coopervid » Sat Oct 19, 2024 9:50 am
doctorvimto wrote: Fri Oct 18, 2024 12:32 am Hi
Most likely a power issue. Connect to an USB-C port ors use a powered USB hub.
Regarding the crossflash you need to post your Makemkv info.
