ragico
#10396 Post by ragico » Sun Oct 13, 2024 2:09 pm
What is Dolby Vision 10.1 profile associated to AV1 codec? And who is using it?
Thank you.
LV8HD
#10397 Post by LV8HD » Tue Oct 15, 2024 3:17 pm
Is it necessary to edit RPU mastering display metadata (not L6) when injecting, or is it better to leave it as it is?
#10398 Post by RESET_9999 » Tue Oct 15, 2024 4:20 pm
never modify the RPU mastering display value (source pq) because dolby calculate the average pq and trims metadata quite differently according to the selected MDL.
see: https://slow.pics/c/rMmXrGeH
kazuma
#10399 Post by kazuma » Tue Oct 15, 2024 8:47 pm
reset_9999, late night devil is one of the few cm 4.0 movies. how is the PQ performance on the ugoos? you said that the conversation was oversatured at te time.
#10400 Post by RESET_9999 » Tue Oct 15, 2024 9:30 pm
first you should verify your RPU because if it was done with makemkv , it's probably wrong.
CMV4.0 works great on the ugoos and the problem with ''the conversation'' bluray is the VERY strong brightening trims that make the image brighter than the HDR master.
deadchip12
#10401 Post by deadchip12 » Tue Oct 15, 2024 11:01 pm
RESET_9999 wrote: Tue Oct 15, 2024 9:30 pm first you should verify your RPU because if it was done with makemkv , it's probably wrong.
How do i verify my RPU?
Or should I just use yours?
#10402 Post by RESET_9999 » Wed Oct 16, 2024 12:15 am
compare the video framecount with the RPU framecount
deadchip12
#10403 Post by deadchip12 » Wed Oct 16, 2024 3:32 am
RESET_9999 wrote: Wed Oct 16, 2024 12:15 am compare the video framecount with the RPU framecount
Sorry I'm quite confused about this new makemkv issue. Which video framecount are you talking about?
Say I want to inject DV from web version to bluray version and already generated RPUs of both using your dovi_script, which framecounts do I have to look at here?
#10404 Post by RESET_9999 » Wed Oct 16, 2024 10:53 am
I'm talking about the original bluray folder that has authoring and muxing issues in MakeMKV like ''Late Night with the Devil''
deadchip12
#10405 Post by deadchip12 » Wed Oct 16, 2024 2:13 pm
RESET_9999 wrote: Wed Oct 16, 2024 10:53 am I'm talking about the original bluray folder that has authoring and muxing issues in MakeMKV like ''Late Night with the Devil''
You mean ripping that movie from the bluray disc using makemkv creates issues?
#10406 Post by RESET_9999 » Wed Oct 16, 2024 2:17 pm
yes, mostly German discs.
recent problematic releases:
-Mississippi Burning
-Late night with the Devil
-Soul eater
if any of these were muxed in makemkv, they are missing half of the DV metadata and flickering is noticeable for the whole movie.
valington
#10407 Post by valington » Wed Oct 16, 2024 6:37 pm
RESET_9999 wrote: Wed Oct 16, 2024 2:17 pm yes, mostly German discs.
-Soul eater
may be this releases will be properly done in mkvtoolnix ?
#10408 Post by RESET_9999 » Wed Oct 16, 2024 7:28 pm
maybe, I dont know. You can also demux with tsmuxer
skull88
#10409 Post by skull88 » Wed Oct 16, 2024 8:25 pm
Not sure if this matters, but makeMKV did recently have another update on Sep 30th, in case it fixed these issues:
MakeMKV v1.17.8 (30.9.2024)
Improved handling for discs with mastering errors and with structure protection
Small improvements and bugfixes
Notable bug fixes:
Audio transcoding failed on Linux when built with recent ffmpeg
#10410 Post by RESET_9999 » Thu Oct 17, 2024 9:26 pm
skull88 wrote: Wed Oct 16, 2024 8:25 pm Not sure if this matters, but makeMKV did recently have another update on Sep 30th, in case it fixed these issues:
I tried the latest version and still had the same issue.
