What is Dolby Vision 10.1 profile associated to AV1 codec? And who is using it?
Thank you.
Thank you.
Is it necessary to edit RPU mastering display metadata (not L6) when injecting, or is it better to leave it as it is?
never modify the RPU mastering display value (source pq) because dolby calculate the average pq and trims metadata quite differently according to the selected MDL.
see: https://slow.pics/c/rMmXrGeH
reset_9999, late night devil is one of the few cm 4.0 movies. how is the PQ performance on the ugoos? you said that the conversation was oversatured at te time.
first you should verify your RPU because if it was done with makemkv , it's probably wrong.
CMV4.0 works great on the ugoos and the problem with ''the conversation'' bluray is the VERY strong brightening trims that make the image brighter than the HDR master.
deadchip12
How do i verify my RPU?RESET_9999 wrote: ↑Tue Oct 15, 2024 9:30 pmfirst you should verify your RPU because if it was done with makemkv , it's probably wrong.
Or should I just use yours?
compare the video framecount with the RPU framecount
deadchip12
Sorry I'm quite confused about this new makemkv issue. Which video framecount are you talking about?
Say I want to inject DV from web version to bluray version and already generated RPUs of both using your dovi_script, which framecounts do I have to look at here?
I'm talking about the original bluray folder that has authoring and muxing issues in MakeMKV like ''Late Night with the Devil''
deadchip12
You mean ripping that movie from the bluray disc using makemkv creates issues?RESET_9999 wrote: ↑Wed Oct 16, 2024 10:53 amI'm talking about the original bluray folder that has authoring and muxing issues in MakeMKV like ''Late Night with the Devil''
yes, mostly German discs.
recent problematic releases:
-Mississippi Burning
-Late night with the Devil
-Soul eater
if any of these were muxed in makemkv, they are missing half of the DV metadata and flickering is noticeable for the whole movie.
-Soul eater
may be this releases will be properly done in mkvtoolnix ?RESET_9999 wrote: ↑Wed Oct 16, 2024 2:17 pmyes, mostly German discs.
-Soul eater
maybe, I dont know. You can also demux with tsmuxer
Not sure if this matters, but makeMKV did recently have another update on Sep 30th, in case it fixed these issues:
MakeMKV v1.17.8 (30.9.2024)
Improved handling for discs with mastering errors and with structure protection
Small improvements and bugfixes
Notable bug fixes:
Audio transcoding failed on Linux when built with recent ffmpeg
Notable bug fixes:
I tried the latest version and still had the same issue.
