BDR-XS07S UHD Flash
panzerschrekk
Re: BDR-XS07S UHD Flash
#121 Post by panzerschrekk » Wed Oct 16, 2024 6:32 am
Is this a supported drive? Seems like it, Firmware from 2020 and V 1.01
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: BADL________
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 19
Drive platform: RS8E20
Firmware version: 1.01
Can i dm you Coopervid? Sorry, you'll probably have to dm me
#122 Post by Coopervid » Thu Oct 17, 2024 9:12 am
panzerschrekk wrote: Wed Oct 16, 2024 6:32 am Is this a supported drive? Seems like it, Firmware from 2020 and V 1.01
OS device name: F:
Revision: 1.01
PM sent.
panzerschrekk
#123 Post by panzerschrekk » Thu Oct 17, 2024 12:43 pm
Coopervid wrote: Thu Oct 17, 2024 9:12 am PM sent.
Thanks alot :)
Dr Zaphod
#124 Post by Dr Zaphod » Mon Oct 28, 2024 5:57 pm
My drive information:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.03
Serienummer: xxxx
Firmware-Datum: 2020-08-20
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
So according to the firmware date I assume it can be patched/cross flashed, correct?
PM would be highly appreciated.
Keep up the great work!
Dr Zaphod
#125 Post by Dr Zaphod » Wed Oct 30, 2024 7:05 am
From my understanding this drive can be flashed?
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BADLxxxx
Firmware date: 2020-08-20
If this is the case a pm would be highly appreciated. Thank You!
bistl
#126 Post by bistl » Tue Nov 12, 2024 2:27 pm
Coopervid, can you send me the instructions please?
Revision: 1.01
Serial number: xxxxxxxxxx
#127 Post by Coopervid » Wed Nov 13, 2024 10:46 am
Dr Zaphod wrote: Wed Oct 30, 2024 7:05 am From my understanding this drive can be flashed?
Revision: 1.03
PM sent.
#128 Post by Coopervid » Wed Nov 13, 2024 10:49 am
bistl wrote: Tue Nov 12, 2024 2:27 pm Coopervid, can you send me the instructions please?
Revision: 1.01
PM is on its way.
bistl
#129 Post by bistl » Wed Nov 13, 2024 2:41 pm
Coopervid wrote: Wed Nov 13, 2024 10:49 am PM is on its way.
Thank you very much!
DaBaDa79
#130 Post by DaBaDa79 » Thu Dec 12, 2024 10:40 pm
Hi, as I have the same drive as hydra I would kindly ask if you can send me the instructions as well. Thanks!
#131 Post by Coopervid » Fri Dec 13, 2024 10:25 am
DaBaDa79 wrote: Thu Dec 12, 2024 10:40 pm Hi, as I have the same drive as hydra I would kindly ask if you can send me the instructions as well. Thanks!
Post your Makemkv info. I will then send a PM accordingly.
Nadme447
#132 Post by Nadme447 » Sat Dec 14, 2024 5:15 am
I have a Pioneer BDR-XS07TS, would this work with the software fix please, or would I need to get a Pioneer BDR-XS07TUHD, apologies I’m not an expert at this. Thanks
DaBaDa79
#133 Post by DaBaDa79 » Sat Dec 14, 2024 6:14 pm
Coopervid wrote: Fri Dec 13, 2024 10:25 am
Of course, here you go:
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: xxxxx
Firmware-Datum: 2020-09-03
#134 Post by Coopervid » Sat Dec 14, 2024 8:30 pm
Nadme447 wrote: Sat Dec 14, 2024 5:15 am I have a Pioneer BDR-XS07TS, would this work with the software fix please, or would I need to get a Pioneer BDR-XS07TUHD, apologies I’m not an expert at this. Thanks
Same thing. Post your Makemkv info.
#135 Post by Coopervid » Sat Dec 14, 2024 8:38 pm
FYI: There are a lot of one time posters who ask for help and then never read their PM to get their drive fixed. This is extremely disappointing. People ask for help, get help and then never check their PMs. That's why I will delete all PMs with help for these people when not read within 14 days. And will not PM again. They need to try to get help elsewhere.
