Aqua Teen Hunger Force Complete Collection Volume 4 Disc 1
loucipher
Post by loucipher » Tue Oct 15, 2024 7:20 pm
I'll start off by saying this is probably due to Adult Swim's historically abysmal DVD authoring, because I've had the same results with 2 copies now.
Basically, on this disc, there are 7 episodes and a bunch of extras. Don't care about the extras, just the episodes. What happens is with makemkv, it reads the disc, no errors, but it only detects 4 titles, 3 of the episodes and one of the extras. These read and rip just fine, but makemkv doesn't see the other 4 titles at all. In handbrake, it sees all the titles, but seemingly can't read them. But the disc does play back fine on a DVD player or in VLC. I've tried multiple drives with the same results in each case. Logs are below, not sure how to troubleshoot this further without sending a disk to Mike :D
$ makemkvcon info disc:0
MakeMKV v1.17.8 linux(x64-release) started
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Title #1 was added (1 cell(s), 0:11:31)
Title #3 was added (1 cell(s), 0:11:30)
Title #7 was added (2 cell(s), 0:11:52)
Title #8 was added (1 cell(s), 0:11:33)
Title #9 has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Total 4 titles
Title 0
0 Video Mpeg2
1 Audio Dolby Digital
2 Audio Dolby Digital
3 Subtitles Dvd Subtitles
4 Subtitles Dvd Subtitles
5 Subtitles Dvd Subtitles
6 Subtitles Closed Captions
Title 1
0 Video Mpeg2
Title 2
0 Video Mpeg2
Title 3
0 Video Mpeg2
Oh, and as an aside, there's still a long-standing bug where makemkvcon on linux refuses to backup a disc because it thinks an empty folder isn't empty:
$ makemkvcon backup disc:0 ./athfs4d1/
Backing up disc into folder "file://./athfs4d1/"
Folder ./athfs4d1/ already contains a backup, please choose another folder
Backup failed
Backup failed.
loucipher
Re: Aqua Teen Hunger Force Complete Collection Volume 4 Disc 1
Post by loucipher » Tue Oct 15, 2024 9:25 pm
As an addendum, the linux
dvdbackup
tool was able to handle this disc. Detects all 7 titles in the titleset with
dvdbackup -i /dev/sr0 -I
Rips them with
for i in {1..7}; do mkdir ep0$i; dvdbackup -i /dev/sr0 -o ./ep0$i -t $i;done
was able to get them into a state that VLC can play with
for i in {1..7}; do mkdir ep0$i; dvdauthor -t -o ./ep0$i ep0$i/Aqua\ Teen\ Hunger\ Force\ Vol4/VIDEO_TS/*.VOB; done
then into a format makemkv could work with via
export VIDEO_FORMAT=ntsc; for i in {1..7}; do cd ep0$i/VIDEO_TS/; dvdauthor -o ../ -T; cd ../..; done
Bit of a circuitous path to get there, but now makemkv can open each episode (treating each one as an individual disc), and create a perfect unconverted copy.
Addendum, not quite perfect, at some point during this process the subtitles get messed up they come out in image format, they're all in black, and they're all but impossible to read. Will update if I fix it.
One more note, disc 2 is similarly jacked, only 3 episodes out of 6 are detected by makemkv. Grabbing the others via the same process works.
Post by dcoke22 » Wed Oct 16, 2024 1:35 am
Have you tried the different DVD Opening Modes in MakeMKV?
loucipher
Post by loucipher » Wed Oct 16, 2024 8:18 pm
I have not, wasn't aware of this functionality, I'll give it a go tonight when my drive is free. Already have what I needed, but good for future reference, thanks!
