suggestion/question
Nitram
suggestion/question
Hello this just an idea, It would be nice if it would save my destination folder info between discs. Example doing a Tv series and have to re-select the correct destination each time I insert a new disc. Please note this is just an idea and maybe there is a way to do this and I just have not figured it out I am a fairly new user.
Re: suggestion/question
Have you set your destination in your configuration? I use the "Semiauto" setting so disks with the same name get routed (by default) to the same destination, but I generally need to edit things because disks are named "disk 2 of x" or similar.
Nitram
Sorry it took me a couple days to get back to you. Thank you that fixed my issue. I missed that when I was looking around in settings.
