Hi
Apologies for the off topic questions. I'm thinking of purchasing a Zidoo media player so I can playback my DVD and Blu ray rips on my tv however I'm a little stumped on which one I should buy because most of the reviews online are for the higher spec 4k and 8k media players not the lower spec ones. So originally I was thinking of buying the Z30 Pro but is quite out of budget at the moment and because it was released only a few months ago there aren't any used examples going for less than £339. So should I buy a used one and if so which one does any Zidoo users here recommend?
Another question I have is can it be possible once I have put all my ripped content onto a SATA drive in my Zidoo to wirelessly copy over any movies (Via its network) I rip later on to avoid me constantly removing it from the player?
Lastly for those who have a Zidoo player how’s the user experience and the technical support? Because I’m planning to have to for many years to come.
Zidoo Media player
Worldwide-Collection
Re: Zidoo Media player
You might be better off getting a Ugoos AM6B+. It plays pretty much everything. Streaming from NAS is the way to go, or use an attached hard drive.Worldwide-Collection wrote: Tue Oct 08, 2024 6:52 pm Hi
Originally I was thinking of setting up a NAS to stream my ripped movies, however I explained in a seperate forum post that I'm worried about any power cuts that could in worst case scenario corrupt the drives (Many bulbs and two clock radios). While a media player such as a Dune or a Zidoo I can switch it off.MartyMcNuts wrote: Fri Oct 11, 2024 11:31 pm You might be better off getting a Ugoos AM6B+. It plays pretty much everything. Streaming from NAS is the way to go, or use an attached hard drive.
Low Winter Sun
Connect your NAS to an UPS. The UPS usually has a USB cable you can connect to your NAS that will let it know of a power interruption, and it will shut itself down.
UNRAID is a nice option.. NAS and RAID!
https://unraid.net/
https://unraid.net/
Worldwide-Collection wrote: Sat Oct 12, 2024 8:57 pm Originally I was thinking of setting up a NAS to stream my ripped movies, however I explained in a seperate forum post that I'm worried about any power cuts that could in worst case scenario corrupt the drives (Many bulbs and two clock radios). While a media player such as a Dune or a Zidoo I can switch it off.
