Can't extract all titles from CSI Season 1 BlueRay
Just got the CSI Season 1 BlueRay set and having issues Ripping some of
the episodes from certain discs. I've attached the requested debug
info.
The tracks that do come off the disc are not able to be played, at least
there's no video anyway the audio seems to be ok. I've tried playing
back the files with VLC and SMplayer and neither can show the video.
The discs work fine in my BlueRay player though.
Using the latest v1.6.12 on Fedora 14 x64
info.
- Contact:
Re: Can't extract all titles from CSI Season 1 BlueRay
The M2TS file is corrupted. Please try making a full disc backup with MakeMKV and see if any hashcheck errors show up.
Did a full backup last night and get errors when trying to extract the titles from the backup, no errors occurred during the backup process. Log attached.
Attempt to extract the disc again using v 1.6.15 and still fails on the same title.
- MakeMKV_log.txt
- (17.71 KiB) Downloaded 1784 times
- Contact:
Unfortunately it IS a bug in MakeMKV and more information may be needed. How soon the error happens after you press "Make MKV" button? Where is the progress indicator - somewhere at start, in the middle or at the end?tabish121 wrote:Attempt to extract the disc again using v 1.6.15 and still fails on the same title.
It happens pretty much right away, only a few seconds after the "Saving 1 titles" log statement as seen above.Operation successfully completed
Saving 1 titles into directory /downloads/Video/CSI_S1_D2
DEBUG: Code 179 at 9{.h}X@7*PC(w=Q>J]n>:29395609
DEBUG: Code 0 at UI.znRq^,P'5_}df%NH6:29394183
DEBUG: Code 140070 at UI.znRq^,P'5_}df%NH6:29393309
Failed to save title 4 to file /downloads/Video/CSI_S1_D2/title04.mkv
0 titles saved, 1 failed
Tested against version 1.6.16 produces the same result
Saving 5 titles into directory /downloads/Video/CSI_S1_D2
Forced subtitles track #4 turned out to be empty and was removed from output file
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 179 at #[c<L8$3]D_E@WCcy;EK:29395609
DEBUG: Code 0 at m;S>l?09e7-cp!$%jD$g:29394183
DEBUG: Code 140070 at m;S>l?09e7-cp!$%jD$g:29393309
4 titles saved, 1 failed
Still failing to as before with version 1.7.0, debug log attached.
- MakeMKV_log.txt
- (12.7 KiB) Downloaded 1945 times
spyderreve
Hate to revive a dead thread but was a solution to this ever found? Having the same issue trying to rip disk 2 from this season.
What does your MakeMKV log say? Please copy & paste the contents into a post here on the forum.spyderreve wrote: Sun Mar 02, 2025 3:23 pm Hate to revive a dead thread but was a solution to this ever found? Having the same issue trying to rip disk 2 from this season.
