A bit confused: "Backup done" but with loads of errors. Files still playing in VLC
shisha0505
#1 Post by shisha0505 » Wed Oct 09, 2024 10:43 am
Hello alltogether,
i'm starting to backup my huge 3D-Bluray collection.
while backing up "Aladdin 3D" i get the error messages according to the log file:
Debug log started at Wed Oct 09 08:43:44 2024 , written by MakeMKV v1.17.8 win(x64-release)
001005:0000 MakeMKV v1.17.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\XXXXXX/MakeMKV_log.txt
No  SDF v098: ATAPI_iHOS104_WL0G_3775204066_250947401547
No auto SDF v098: ATAPI_iHOS104_WL0G_3775204066_250947401547
DEBUG: Code 0 at H.L>:vj.[<bHehWh[:29396253
DEBUG: Code 0 at e`1A[8IgfdJS=V\(:213136746
DEBUG: Code 3 at E}P)4^&Zt'eI2]i`NTMR>^^t:29395310
SDF id v098: ATAPI_iHOS104_WL0G_3775204066_250947401547
No  SDF v098: Slimtype_eBAU108__7_L_YL0M_3734508400_426027500310
SDF id v098: Slimtype_eBAU108__7_L_YL0M_3734508400_426027500310
MMBDINST: Launching C:\Program Files (x86)\MakeMKV/makemkvcon64.exe
MMBDINST: HELLO 00
Put libmmbd64.dll -> C:\Program Files\VideoLAN\VLC/libmmbd.dll
MMBDINST: MMBD installer exiting.
001003:0020 DEBUG: Code 117506188 at e2ZHo%(J'4phL9N]&.:121263429
001003:0020 DEBUG: Code 117506188 at e2ZHo%(J'4phL9N]&.:121262302
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '48580329472'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '47061532672'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '47061585920'
001003:0020 DEBUG: Code 0 at o%A$s5!\;(w\XWd:121262509
001003:0020 DEBUG: Code 0 at o%A$s5!\;(w\XWd:213129846
001003:0020 DEBUG: Code 1 at o%A$s5!\;(w\XWd:29395264
005084:0000 Failed to load content hash table, unable to verify integrity of M2TS files.
DEBUG: Code 2147483648 at VtT$hoa+N}'B:VS3:121265499
002004:0000 Error 'OS error - nt:8701003a' occurred while issuing SCSI command 4602010D0..010 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at ,Z;R,PU|d7&+YhOy;O:213130237
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003338:0000 Downloading latest HK to C:\Users\XXXXXX/.MakeMKV ...
003339:0000 Automatic HK downloading is disabled or failed.
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '7733248'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '7776256'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '14680064'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '14733312'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '8781824'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '8824832'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '15728640'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '15781888'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '3145728'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '3158016'
001012:0000 udf: 	node fe/efe failed!
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '4915200'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '11993088'
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ATAPI iHOS104 WL0G 3775204066 250947401547' at offset '12042240'
001003:0020 DEBUG: Code 0 at oc.FaWOiWiK3AGYe.:121265085
001003:0020 DEBUG: Code 2264989754 at oc.FaWOiWiK3AGYe.:213133848
003332:0000 Saved AACS dump file as file://C:\Users\XXXXXXX/.MakeMKV/MKB_v68_Aladdin_(Live_Action)_319C.tgz
001003:0020 DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
001003:0020 DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
005072:0000 Backing up disc into folder "file://F:/MAKEMKV/ALADDIN_3D"
001003:0020 DEBUG: Code 0 at L+:;ML5eZ-9XKa3x:121262302
DAFD=PAAAADAAAAEABDQEEAAADAQ==
DCE=Gjnhao4Xqh+vbB/XwDJn3gLJ4fFVlChOzCEYnftFY1nRjZqDhjunEO9HagVpLAWJnkI/Hk+0lvxd5VbxycWM4NMtMec+SL+vnH0gd0eBXlxQmMk6/JdZrAe1GEiWq5qqrJJAnylmQ5AugEmGrFRFHGTFyQlDy+gz+A==
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Wed Oct 09 10:08:52 2024
Nonetheless the backup finishes apparently successful.
When i open the *.mts files with VLC they play without problems.
But since i'm in the beginning of the backing up process i haven't yet created any set up where i could test if the backups will actually will work in 3D.
Can anyone be so kind and briefly check what might be the problem (if there is any problem at all despite the error messages)?
many thanks in advance
Re: A bit confused: "Backup done" but with loads of errors. Files still playing in VLC
#2 Post by dcoke22 » Thu Oct 10, 2024 5:14 pm
Do you have two optical drives? It looks like there's a disc in the other optical drive that the drive can't read.
shisha0505
#3 Post by shisha0505 » Thu Oct 10, 2024 5:56 pm
no, only the LiteOn iHOS104
the Aladdin BluRay wasn't the only disk that produced that error yesterday.
Geostorm 3D had similiar issues while other BluRays copied with no error message.
But this is strange: today i gave it another try. First with Geostorm, which finished without any error.
Right now a new attempt of backing up Aladdin is running. At the very moment at elapsed time 16 minutes with another 47 minutes to go.
No error message so far. (knock knock knock on wood...)
PS: Aladdin backup finished with no error message
