ASUS SBW-06D2X-U
Jam1668
ASUS SBW-06D2X-U
Post by Jam1668 » Sat Oct 05, 2024 1:51 pm
I have bought this drive and I was wondering if it is possible to change my firmware from D601 to 1.10?
Current profile: DVD-ROM
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: D601
Serial number: [redacted]
Highest AACS version: 68
Re: ASUS SBW-06D2X-U
Post by Coopervid » Sun Oct 06, 2024 10:38 am
Manufacturer: ASUS
Revision: D601
We need to see the whole information including "Drive platform".
dihjaskd
Post by dihjaskd » Mon Oct 07, 2024 5:40 pm
My Drive is a:
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: <redacted>
Firmware date: 2017-04-18
Firmware version: ID22
Is there a way to make it libredrive ready ?
Post by Coopervid » Mon Oct 07, 2024 6:56 pm
My Drive is a:
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Check your PM.
dihjaskd
Post by dihjaskd » Mon Oct 07, 2024 7:27 pm
Thank you so much. It worked perfectly on the first try.
Awesome work also on the documentation and tutorial.
Jam1668
Post by Jam1668 » Wed Oct 09, 2024 6:43 pm
Manufacturer: ASUS
Revision: D601
The drive platform isn't shown for some reason
Post by Coopervid » Wed Oct 09, 2024 7:04 pm
Manufacturer: ASUS
Revision: D601
Then it is an unknown drive platform and can't be upgraded to UHD. Sorry but ASUS is just a reseller of many OEM drives like LG, Pioneer and more.
AjUK1
Post by AjUK1 » Wed Oct 09, 2024 10:59 pm
Hi i also have this drive and was wanting to upgrade to be able to rip 4ks UHD have been using for blu rays and dvds was have started collecting UHDs any help is appreciated.
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 81
Thanks in advanced
Post by Coopervid » Thu Oct 10, 2024 9:32 am
Manufacturer: ASUS
Revision: 1.10
Thanks in advanced
PM sent.
AjUK1
Post by AjUK1 » Sat Oct 12, 2024 1:38 pm
Perfect that worked Thanks again
keaney2023
Post by keaney2023 » Mon Oct 21, 2024 2:58 pm
Hi also looking for confirmation if mine will work:
Manufacturer: ASUS
Revision: 1.10
Serial number: redacted
Post by Coopervid » Mon Oct 21, 2024 3:02 pm
Manufacturer: ASUS
Revision: 1.10
It should. Read your PM.
keaney2023
Post by keaney2023 » Tue Oct 22, 2024 9:09 am
Success! thanks for your help... updated info:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
DJNachos
Post by DJNachos » Sun Oct 27, 2024 7:47 pm
Hello, I am also wondering if this particular drive has a patch available for 4k UHD discs please; if not thank you for your time regardless.
OS device name: O:
Manufacturer: ASUS
Revision: 1.10
Serial number:
Highest AACS version: 76
lord_farfig
Post by lord_farfig » Mon Nov 04, 2024 6:49 pm
Hello!
I picked up an Asus SBD-06D2X-U recently, however, I'm having trouble with MakeMKV reading disks in Linux (drive seems to work OK in Windows).
Drive details:
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
I have a firmware dump from Windows and can provide if needed.
Thank you!
