BP50NB40 NB72 - Unable to flash
I am pretty new in the game here, so excuse me if this issue come off as a rookie mistake.
I have an LG BD50NB40 with SVS code NB72, manufactured in 2023. It seems that I am not able to flash the firmware using SDFtool Flasher.
I get the error message 'the drive you have selected does not have the correct drive platform' and I see a red cross at MT1959 Platform.
Drive information from MakeMKV shows this:
Product: BD-RE BP50NB40
Revision: 0403
Serial number: [redacted]
Highest AACS version: 50
Am I completely out of luck flashing this drive, or did I miss steps beforehand?
I can't seem to find any information for the specific revision no. or SVS code.
I would appreciate any feedback to this - Thanks!
Revision: 0403
Re: BP50NB40 NB72 - Unable to flash
Did you set the flashed to "enc" (encoded) software flashing? If not, it will fail on that new of a drive.
By "enc" you mean ticking the Encrypted Firmware? Yes I tried that with no luck.
I even tested it out in the older version of SDFtool, where I tick the "enc". When pressing start nothing happens.
Oh, and by the way. No Libredrive information is showing up in MakeMKV.
I have opened plenty of blurays through MakeMKV before, so I guess it should have downloaded the Libredrive info?
Hmm bp72 is new usually bp52.Broomie wrote: Thu Oct 10, 2024 5:24 pm By "enc" you mean ticking the Encrypted Firmware? Yes I tried that with no luck.
Email me it's free if its a new procedure
Thanks, I've sent you an email.Billycar11 wrote: Thu Oct 10, 2024 6:35 pmHmm bp72 is new usually bp52.Broomie wrote: Thu Oct 10, 2024 5:24 pm By "enc" you mean ticking the Encrypted Firmware? Yes I tried that with no luck.
I'm not sure if you've seen it but there is a new BU40N firmware release from June 2024: v1.05 (https://www.lg.com/us/support/software- ... 0N.AVAA10B)Billycar11 wrote: Thu Oct 10, 2024 6:35 pm Hmm bp72 is new usually bp52.
Hopefully LG haven't put too much effort into securing these latest drives and firmware updates.
Edit: I'm not too familiar with the stock firmware flashing tools but 17/73 vendors on Virustotal flagged the new LG update utility: https://www.virustotal.com/gui/file/e84 ... 4e457ee25f
Hopefully this is just an indicator of some level of obfuscation
I already tested 1.05 it downgrades like normal nothing to worry about.
ryley wrote: Tue Oct 15, 2024 12:31 pm
Jimbanville
Did you get it to work? I’m totally new to this and was going to pick up this drive for 4k ripping. Thanks!Broomie wrote: Thu Oct 10, 2024 8:17 am Hi,
Revision: 0403
You should read this and you picked the most cumbersome one to flash:Jimbanville wrote: Wed Oct 23, 2024 2:04 pmDid you get it to work? I’m totally new to this and was going to pick up this drive for 4k ripping. Thanks!Broomie wrote: Thu Oct 10, 2024 8:17 am Hi,
Revision: 0403
viewtopic.php?f=16&t=19634
Read the bottom section in "Recommended firmware to flash".
I will have to update the guide nb72 does not seem to be a media tech controller drive so new ones of those won't work
So? Any remedy?Billycar11 wrote: Wed Oct 23, 2024 7:39 pm I will have to update the guide nb72 does not seem to be a media tech controller drive so new ones of those won't work
For NB72 no can't do UHD from what I can tell Mike could change that but he would have to have a look at itCoopervid wrote: Wed Oct 23, 2024 7:48 pmSo? Any remedy?Billycar11 wrote: Wed Oct 23, 2024 7:39 pm I will have to update the guide nb72 does not seem to be a media tech controller drive so new ones of those won't work
Damn. New challenge.Billycar11 wrote: Wed Oct 23, 2024 7:52 pmFor NB72 no can't do UHD from what I can tell Mike could change that but he would have to have a look at itCoopervid wrote: Wed Oct 23, 2024 7:48 pmSo? Any remedy?Billycar11 wrote: Wed Oct 23, 2024 7:39 pm I will have to update the guide nb72 does not seem to be a media tech controller drive so new ones of those won't work
Thanks for the update Billy, I'm glad to hear there are no new challenges for BU40N drives.Billycar11 wrote: Wed Oct 16, 2024 7:03 pm I already tested 1.05 it downgrades like normal nothing to worry about.
It is surprising to hear that NB72 isn't using a Mediatek controller. Are they using a Pioneer solution? If not, has there ever been a third company which produced a BDXL-compatible drive platform?Billycar11 wrote: Wed Oct 23, 2024 7:39 pm I will have to update the guide nb72 does not seem to be a media tech controller drive so new ones of those won't work
