morbius
#10366 Post by morbius » Tue Oct 01, 2024 7:55 pm
I saw a bit of discussion on this up thread, is there an explanation for why cm_analyze gradually slows down during its analysis in the 3-1 workflow, with the effective fps rate gradually dropping? Happens with every title I've done so far (I'm using Win 10).
#10367 Post by RESET_9999 » Wed Oct 02, 2024 12:54 am
morbius wrote: Tue Oct 01, 2024 7:55 pm I saw a bit of discussion on this up thread, is there an explanation for why cm_analyze gradually slows down during its analysis in the 3-1 workflow, with the effective fps rate gradually dropping? Happens with every title I've done so far (I'm using Win 10).
viewtopic.php?p=141657#p141657
#10368 Post by RESET_9999 » Wed Oct 02, 2024 4:22 pm
RESET_9999 wrote: Sat Aug 24, 2024 3:22 pm Yep, I just tried with makemkv and the RPU seems to go out of sync at frame 32982.
I did not watch it but the scene cuts seem fine if I demux with tsmuxer and use dovi_tool.exe to make the ST-DL hevc.
makemkv scene cuts (OOS): https://justpaste.it/a8i23
tsmuxer demux scene cuts: https://justpaste.it/cmmbn
and the rpu is missing frames and is 5kb smaller with makemkv: https://slow.pics/c/AbM7fpJV
another one: Mississippi.Burning.1988
Makemkv missing half of the metadata: https://slow.pics/c/XtZD09Hp
no issue with tsmuxer... I guess the makemkv output should always be double checked...
skull88
#10369 Post by skull88 » Wed Oct 02, 2024 5:01 pm
I have a feeling MakeMKV issue is only with some discs that have seamless branching, but just a guess. Could post on this forum some kind-of bug report for it? Maybe the dev would be able to figure it out by talking to quietvoid or something. Worth verifying though, agreed.
#10370 Post by RESET_9999 » Wed Oct 02, 2024 5:06 pm
this one is not a seamless branching disc.
skull88
#10371 Post by skull88 » Wed Oct 02, 2024 5:09 pm
Hmm, that's strange. I wonder what it is then? Maybe there are multiple cases where RPU ends up incomplete? I'll make a bug report post one day if I have time and figure out the pattern. Do you know if quietvoid uses makeMKV and could advise at all?
morbius
#10372 Post by morbius » Wed Oct 02, 2024 8:02 pm
RESET_9999 wrote: Wed Oct 02, 2024 12:54 am
thanks for that, saves me the trouble of more tinkering with my set-up to try and fix it. Will watch the thread with interest to see if a fix is available in due course.
quietvoid
#10373 Post by quietvoid » Thu Oct 03, 2024 1:24 am
skull88 wrote: Wed Oct 02, 2024 5:09 pm Hmm, that's strange. I wonder what it is then? Maybe there are multiple cases where RPU ends up incomplete? I'll make a bug report post one day if I have time and figure out the pattern. Do you know if quietvoid uses makeMKV and could advise at all?
There have been many different issues in the past:
- Non synced BL/EL
- Different M2TS/container timestamps
They are all authoring problems.
Usually MakeMKV reports errors but for some people it never does.
This one looks different since the metadata is randomly missing across the whole title?
Iam2smart
#10374 Post by Iam2smart » Sat Oct 05, 2024 9:33 pm
Hi is there a way to speed up MadVR plotting? it just takes a long time even on a i9-13900k, Hope you all can help, Thanks
EDIT: I Figured it out I had to setup LAVFilters. Thanks
valington
#10375 Post by valington » Wed Oct 09, 2024 7:37 am
RESET_9999 wrote: Mon Sep 23, 2024 2:29 pm
morbius wrote: Mon Sep 23, 2024 11:36 am I've converted several HDR10 titles to DV using the 6-2 and 3-1 workflows and have been pleased with the results. With 6-2 I've been selecting "n" for exclude letterbox for estimating MaxFALL due to the warning about processing time. To what extent might this impact the end result? I only want to convert my library once, so don't want to take short-cuts if they are undermining final quality.
if you just use 6-2 to create a shot list for 3-1 it doesn't matter.
LV8HD wrote: Sun Sep 22, 2024 2:49 pm Why is MaxCLL calculated with DaVinci Resolve so different than MadVR? What is the most accurate?
different algo
Reset what you think about relise of wolverine and deadpool from kaleidascape striming resource which is on torrents now ?
#10376 Post by RESET_9999 » Wed Oct 09, 2024 10:38 am
its fake
TheEqualizer
#10377 Post by TheEqualizer » Wed Oct 09, 2024 12:46 pm
RESET_9999 wrote: Wed Oct 09, 2024 10:38 amits fake
Good afternoon, how can you be so sure, how did you manage to recognize it? I want to look into this issue, the Chinese SasukeducK has not yet given clear answers. Yesterday I did a little analysis of track 7.1, all the channels are different there, i.e. the side and rear are different, there is no way to take 7.1 from where, either he converted TrueHD Atmos 7.1 from Kaleidescape to eac3 7.1 or decomposed eac3 5.1 768 atmos into 16 channels and slipped a couple of channels of effects into this 7.1, to mislead everyone.
(Sorry for my English, translated by google)
#10378 Post by RESET_9999 » Wed Oct 09, 2024 12:56 pm
Because the pixels are 1:1 identical to the Movie Anywhere Web-dl. This is not possible and this group has a history of faking web-dl.
Also, if you really can crack / web-dl KS, why not offer the TrueHD Atmos track as well?
TheEqualizer
#10379 Post by TheEqualizer » Wed Oct 09, 2024 12:58 pm
RESET_9999 wrote: Wed Oct 09, 2024 12:56 pm Because the pixels are 1:1 identical to the Movie Anywhere Web-dl. This is not possible and this group has a history of faking web-dl.
Any idea how he faked the sound? Perhaps the second option that I suggested, or are there any other thoughts on this?
TheEqualizer
#10380 Post by TheEqualizer » Wed Oct 09, 2024 12:59 pm
RESET_9999 wrote: Wed Oct 09, 2024 12:56 pm Also, if you really can crack / web-dl KS, why not offer the TrueHD Atmos track as well?
There were doubts about this too
