SDFtool Flasher firmware backup
Rai4321
Post by Rai4321 » Tue Oct 08, 2024 11:49 am
I am trying to backup firmware from my drive under Debian 12/MakeMKV 1.17.8
# Lists all available drives
sdftool --list
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
PIONEER_BD-RW___BDR-UD04_1.14_XyXyXyXyXyXy
# Dump drive firmware
sdftool -d /dev/sr0 dump -o $HOME/.MakeMKV/ -vvvv
Found sdf.bin version 0x98 at /home/rai4321/.MakeMKV/_private_data.tar
Loaded SDF.bin version 0x98
Found drive-specific logic in SDF.bin
Using (non-existing) config file at /home/rai4321/.libdriveio/sdf.conf
but nothing much happened for past 20min ...
Re: SDFtool Flasher firmware backup
Post by Coopervid » Tue Oct 08, 2024 12:05 pm
Why do you want to do that?
As a first sdftool is only used to flash LG / ASUS drives. It also doesn't make a useful firmware backup for these drives.
Secondly Makemkv produces a firmware dump for Pioneer drives BUT only if Makemkv finds a firmware that is unknown to it.
Rai4321
[SOLVED] Re: SDFtool Flasher firmware backup
Post by Rai4321 » Tue Oct 08, 2024 12:15 pm
I am playing around with what the tools that come part of MakeMKV can do,
and just wanted to back up the firmware if I can ..... on the drive ....
Thanx for the info :)
Post by Coopervid » Tue Oct 08, 2024 9:59 pm
And don't even think about flashing new Pioneer firmware to this drive!!! You would lose the UHD capability. I sense that you are screwing with everything these days. Don't do stupid stuff! Ask in the forum before you do so!
