Pioneer BDR-XS07U FIrmware?
blutuna
#1 Post by blutuna » Sat Oct 05, 2024 3:36 pm
I came across this drive while looking for something else (not sure when/where I got it) and wondering what firmware would be best to use for it?
I ripped about a dozen of my 4Ks with it no problem, then it choked on 2 in a row, wouldn't open them.
Here's the drive info...
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8E21
Firmware version: 1.01/ID05
Re: Pioneer BDR-XS07U FIrmware?
#2 Post by Coopervid » Sat Oct 05, 2024 4:03 pm
Revision: 1.01
Clean UHD discs with liquid soap and warm water. The dry with a paper towel and wipe with a microfiber cloth. Try again.
blutuna
#3 Post by blutuna » Sat Oct 05, 2024 4:45 pm
Hi, thx for the reply!
I've cleaned it several times now (Infinity War), can see nothing on the disc, no foreign matter, smudges etc.
Stops about halfway through.
The second one that it wouldn't read worked in my LG drive.
The LG drive won't read this disc either.
#4 Post by MartyMcNuts » Sat Oct 05, 2024 10:08 pm
Revision: 1.01
The firmware is not the issue. Don't ever change it!!!
The discs are the problem. Clean them before trying again.
blutuna
#5 Post by blutuna » Mon Oct 07, 2024 8:42 am
Ah, ok. I was wondering if it was a firmware issue. Thx for the reply!
pizzle21
#6 Post by pizzle21 » Wed Oct 09, 2024 7:06 pm
i currently have 1 Pioneer BDR_XS07 and im thinking of getting another for my 2nd laptop. this is the current info on my one drive. i bought a 2nd one but as soon as i put the disk in it ejected it in a second. which firmware version should i be looking for. the last one had a firmware of 1.01 plus which one will work for UHD Disks
current one
Current profile: DVD-ROM
Revision: 1.02
Firmware date: 2022-10-24
Highest AACS version: 81
Firmware version: 1.02/ID05
#7 Post by Coopervid » Mon Oct 14, 2024 4:17 pm
current one
Revision: 1.02
This should work. Newer ones won't as they have encrypted firmware. Sounds like a power issue. Use a high powered USB port or an USB hub with a power supply. But the newest firmware I have is 1.01 that works for UHD. Maybe 1.02 is already encrypted. We assumed until now that only newer than Dec. 2022 will not work anymore.
#8 Post by MartyMcNuts » Mon Oct 14, 2024 9:57 pm
current one
Revision: 1.02
1.02 is fine and is already enabled. Don't touch the firmware. You have other issues.
As coop said, try a more powerful USB port. Geez I hate those slot load drive's. Bloody terrible things they are!
