Can the WP50NB40 Rip 4K Blu-Rays???
Mercilesswaysdesigns
I recently purchased this drive and flashed it to it’s listed file in the all you need folder. It does not read 4K Blu-Rays. Should this be cross flashed to a different firmware in order to do so?
Re: Can the WP50NB40 Rip 4K Blu-Rays???
**UPDATE**
I had successfully ripped some regular Blu-Rays and a bunch of DVD’s. Now for some reason it’s nonstop failures. It keeps saying 1 file failed hash check?
Read the forum posts and don't be lazy.
I read through a ton of posting and didn't see this specifically posted... This is also very new to me so I am not sure what exactly I am looking for but thanks for calling me lazy even though I have spent hours on this forum. You are very helpful....
viewtopic.php?f=16&t=19634Mercilesswaysdesigns wrote: Mon Oct 07, 2024 2:38 pmI read through a ton of posting and didn't see this specifically posted... This is also very new to me so I am not sure what exactly I am looking for but thanks for calling me lazy even though I have spent hours on this forum. You are very helpful....
However, read carefully how to flash your drive. It's a 2 step process described in the guide.
Also detailed in the 1st post... SDFtool FlasherMercilesswaysdesigns wrote: Mon Oct 07, 2024 2:38 pmI read through a ton of posting and didn't see this specifically posted... This is also very new to me so I am not sure what exactly I am looking for but thanks for calling me lazy even though I have spent hours on this forum. You are very helpful....
