BDR-XS07S UHD Flash
LordFoxington
Re: BDR-XS07S UHD Flash
Post by LordFoxington » Thu Sep 19, 2024 11:14 pm
Hello Coopervid. If possible, I would like to flash, or crossflash the following drive please:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: XXXXXXXXX
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8E20
Firmware version: 1.01
Post by Coopervid » Fri Sep 20, 2024 5:31 pm
LordFoxington wrote: Thu Sep 19, 2024 11:14 pm Hello Coopervid. If possible, I would like to flash, or crossflash the following drive please:
Revision: 1.01
PM is coming.
LordFoxington
Post by LordFoxington » Fri Sep 20, 2024 6:35 pm
Thank you very much Coopervid! I greatly appreciate your help.
flojo
Post by flojo » Mon Sep 23, 2024 7:37 pm
Coopervid wrote: Fri Sep 13, 2024 4:26 pm
flojo wrote: Thu Sep 12, 2024 12:44 pm Could you PM the link too? I just picked one up.
Just by holding this it feels cheap. Who actually manufacturers the Pioneer USB slim drives and are they the same quality as their 5.25 drives?
I know Pioneer outsources most or all electronics today. For instance I have a PLX-1000 record player and while it is very good, it's not fabricated or designed by Pioneer. I know that their original 3.25 floppy drives were Toshiba although I believe their first consumer DVD-ROM (100D?? 101A?? .. big SCSI thing) was actually made my them.
Post your Makemkv info.
Thank you, but in retrospective I don't think it will read UHD discs....
OS device name: /dev/sr0
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Highest AACS version: 72
Drive platform: RS8D30
Firmware version: 1.02
Post by Coopervid » Mon Sep 23, 2024 7:39 pm
flojo wrote: Mon Sep 23, 2024 7:37 pm
Thank you.
Revision: 1.02
Serial number:
PM is coming.
flojo
Post by flojo » Mon Sep 23, 2024 9:17 pm
Thanks cooper!!
I can add that the flash worked fine using VMware Workstation 17 Player 17.5.0 build-22583795 on Ubuntu 24.04 6.8.0-41-generic and the 64bit windows iso Windows 10 2023 Update | Version 22H2 from here https://www.microsoft.com/en-gb/softwar ... ndows10ISO
Thanks again!!
Fight_On
Post by Fight_On » Mon Sep 23, 2024 9:51 pm
Coopervid, can this drive be flashed? If so could you PM me the info? Thanks in advance!
Revision: 1.03
Serial number: [redacted]
Firmware date: 2023-01-06
Drive platform: Pioneer RS8E20
Firmware version: GENE
Post by Coopervid » Mon Sep 23, 2024 10:36 pm
Fight_On wrote: Mon Sep 23, 2024 9:51 pm Coopervid, can this drive be flashed? If so could you PM me the info? Thanks in advance!
Revision: 1.03
No. You are screwed. The FW is newer than Dec. 2022.
Fight_On
Post by Fight_On » Tue Sep 24, 2024 4:46 am
What about this one:
OS device name: /dev/rdisk5
Product: BD-RW BDR-XS06
Revision: 1.01
Firmware date: 2015-03-24
Highest AACS version: 77
Drive platform: RS8721
Firmware name: PIONEER BDR-XS06
Mgear
Post by Mgear » Sat Oct 05, 2024 10:25 pm
Dear Coopervid,
Could you help me out with my pioneerdrive to read uhd ?
Revision: 1.01
Serial number:
Post by Coopervid » Sun Oct 06, 2024 10:22 am
Fight_On wrote: Tue Sep 24, 2024 4:46 am What about this one:
Revision: 1.01
No possibility for the XS06.
Post by Coopervid » Sun Oct 06, 2024 10:23 am
Mgear wrote: Sat Oct 05, 2024 10:25 pm Dear Coopervid,
Revision: 1.01
Serial number:
PM sent.
Mgear
Post by Mgear » Sun Oct 06, 2024 10:42 am
youre the bomb cooper it works perfectely! thank you so much!
Voxelium
Post by Voxelium » Wed Oct 09, 2024 8:32 pm
Coopervid wrote: Wed Mar 20, 2024 4:44 pm
qlxel wrote: Wed Mar 20, 2024 2:21 pm Hello Coopervid,
could you please send me the instructions as well?
Check PM.
Hi Coopervid,
Would you be able to PM me with instructions?
Thank you very kindly,
Voxelium
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Post by Coopervid » Thu Oct 10, 2024 9:29 am
Voxelium wrote: Wed Oct 09, 2024 8:32 pm
Check PM.
Hi Coopervid,
Voxelium
If you have Pioneer drives (Superdrive?) you need to post their Makemkv info with the "Drive platform" information.
