Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
ianfrancorchamps
MKB20_v77_88FU026_63C0.tgz
Re: Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
Excellent. My disc is hopefully coming in the next few days.
keydb_helper
The 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
Public KeyDB Disc Submissions
ianfrancorchamps
Thank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 amThe 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
keydb_helper
Yes, download and extract the latest keydb fileianfrancorchamps wrote: Sat Oct 05, 2024 7:13 amThank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 amThe 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
ianfrancorchamps
It worked perfectly. Thanks a lot for your hard workkeydb_helper wrote: Sat Oct 05, 2024 7:25 amYes, download and extract the latest keydb fileianfrancorchamps wrote: Sat Oct 05, 2024 7:13 amThank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 am
Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
viewtopic.php?f=12&t=32784
ianfrancorchamps
Thanks mate, I'll give it a try sometimeCoopervid wrote: Sat Oct 05, 2024 10:25 am Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
