Failure to open ripped folder
CrazyGuy207
#1 Post by CrazyGuy207 » Thu Oct 03, 2024 3:29 am
First time posting, I hope I'm not posting this in the wrong board.
I used MakeMKV to make a backup of a blu-ray disc like I usually do. The process completed with no problems, but now an issue I haven't seen before comes up. When I try to open the folder in HandBrake, it tells me "No Valid Source or Titles found". I ripped a season of a series, and all other discs in the box open like normal. When I try to open the folder in CyberLink Media Suite 16, it won't open in there either. However, when I try to open it in VLC, it'll play the videos with no issue. What's going on here? Should I re-rip the disc? I'd rather not convert these files in VLC, for consistencies sake. Is the issue with the disc, handbrake, or makemkv?
Thank you in advance.
Ezatoka
Re: Failure to open ripped folder
#2 Post by Ezatoka » Thu Oct 03, 2024 4:44 pm
What kind of files and/or folders are in the output directory?
#3 Post by dcoke22 » Thu Oct 03, 2024 5:27 pm
Does MakeMKV open the backup successfully?
My typical workflow is to make a decrypted backup of a disc, open the backup in MakeMKV and create the .mkv files I'm interested in, then, optionally, transcode the .mkv files with Handbrake.
CrazyGuy207
#4 Post by CrazyGuy207 » Fri Oct 04, 2024 3:04 am
"BDMV", "CERTIFICATE", and "MAKEMKV"
CrazyGuy207
#5 Post by CrazyGuy207 » Fri Oct 04, 2024 3:07 am
It usually does, but not this time. The ripped disc created the backup folder, and I can even go into the BDMV > STREAM folder to open the episodes, but HandBrake and other video apps don't seem to recognize the ripped folder/backup and won't open. I wasn't sure if this was a MakeMKV issue or with HandBrake.
#6 Post by dcoke22 » Fri Oct 04, 2024 6:53 pm
Interesting. I've never encountered a case where I've successfully made a backup of a disc that MakeMKV could not then open. I almost never use VLC or Handbrake on a backup, so I have no experience with how reliable (or not) they are operating on a backup.
If you make a new backup of the problematic disc, does it also have the problem?
Ezatoka
#7 Post by Ezatoka » Fri Oct 04, 2024 6:56 pm
what happens, if you use "Open files" in MakeMKV and let it open the index.bdmv file in the BDMV folder? Does it recognize the disk itself anymore?
CrazyGuy207
#8 Post by CrazyGuy207 » Sat Oct 05, 2024 9:10 pm
Sorry if I wasn't clear. MakeMKV isn't the issue here, HandBrake is. MakeMKV made the backup of my disc just fine, but HandBrake doesn't recognize it. I wasn't sure if it was an issue with which system though, as I've never seen this problem before.
Ezatoka
#9 Post by Ezatoka » Sun Oct 06, 2024 8:26 am
Then I am afraid you should place your question at the Handbrake Forum.
