Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
differentiate wrote: Sat Oct 05, 2024 8:08 am Hi, I followed your advice and ordered a Vinpower BDR 212V, which will arrive Monday. Any help or guidance to enable libredrive is much appreciated.
PM sent.
nicktenn wrote: Sat Oct 05, 2024 3:31 pm Just want to confirm that the drives sold here with flashed firmware will work fine in a dx2 on a Mac Studio running makemkv right?
Right.
TheSpuggy
Post by TheSpuggy »
Hi, i am in the uk and looking to buy a drive that will use the Libre drive can someone recommend a reliable drive for this. for home use not doing anything too silly with it. i just want to have a go. please PM me the info.
TheSpuggy wrote: Sat Oct 05, 2024 7:15 pm Hi, i am in the uk and looking to buy a drive that will use the Libre drive can someone recommend a reliable drive for this. for home use not doing anything too silly with it. i just want to have a go. please PM me the info.
Raed your PM.
dmdmmatt4
Post by dmdmmatt4 »
I'm also looking for a 5.25" drive in an external enclosure for libredrive / 4k ripping..
dmdmmatt4 wrote: Sun Oct 06, 2024 9:01 pm I'm also looking for a 5.25" drive in an external enclosure for libredrive / 4k ripping..
Country of residence please.
tvanbuskirk
Post by tvanbuskirk »
Coopervid-
I have also purchased the Vinpower BDR-212V from Amazon:
https://www.amazon.com/dp/B08R89FN61?re ... title&th=1
Could I also get the instructions for the flasher?
TIA!
tvanbuskirk wrote: Sun Oct 06, 2024 11:26 pm Coopervid-
TIA!
PM sent.
dmdmmatt4
Post by dmdmmatt4 »
Coopervid wrote: Sun Oct 06, 2024 10:36 pm
UK..
dmdmmatt4 wrote: Mon Oct 07, 2024 2:46 pm
UK..
PM sent.
toddself
Post by toddself »
TIA!
i too have this drive — can you please send me the flashing instructions?
thank you!
toddself wrote: Wed Oct 09, 2024 2:40 pm
TIA!
thank you!
PM sent.
robinwatts
Post by robinwatts »
I have an internal 5.25" blu ray writer that works well for normal ripping.
I might be interested in upping that to a drive capable of ripping 4k discs. I'm in the UK. What's the best drive options for this? (both internal and external).
robinwatts wrote: Wed Oct 09, 2024 6:58 pm I have an internal 5.25" blu ray writer that works well for normal ripping.
PM sent.
tvanbuskirk
Coopervid wrote: Mon Oct 07, 2024 10:06 am
TIA!
PM sent.
Thanks CooperVid! Worked perfectly!
