Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
ianfrancorchamps
#1 Post by ianfrancorchamps » Fri Oct 04, 2024 3:48 am
MKB20_v77_88FU026_63C0.tgz
extranet
Re: Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
#2 Post by extranet » Fri Oct 04, 2024 10:57 am
Excellent. My disc is hopefully coming in the next few days.
keydb_helper
#3 Post by keydb_helper » Sat Oct 05, 2024 6:53 am
The 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
ianfrancorchamps
#4 Post by ianfrancorchamps » Sat Oct 05, 2024 7:13 am
Thank you, should I download the latest keydb.cfg file?
keydb_helper
#5 Post by keydb_helper » Sat Oct 05, 2024 7:25 am
Yes, download and extract the latest keydb file
ianfrancorchamps
#6 Post by ianfrancorchamps » Sat Oct 05, 2024 10:18 am
It worked perfectly. Thanks a lot for your hard work👍
#7 Post by Coopervid » Sat Oct 05, 2024 10:25 am
Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
viewtopic.php?f=12&t=32784
ianfrancorchamps
#8 Post by ianfrancorchamps » Sun Oct 06, 2024 4:34 am
Thanks mate, I'll give it a try sometime
