Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
ianfrancorchamps
MKB20_v77_88FU026_63C0.tgz
extranet
Re: Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
Excellent. My disc is hopefully coming in the next few days.
keydb_helper
The 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
ianfrancorchamps
Thank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 amThe 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
keydb_helper
Yes, download and extract the latest keydb fileianfrancorchamps wrote: Sat Oct 05, 2024 7:13 amThank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 amThe 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
ianfrancorchamps
It worked perfectly. Thanks a lot for your hard workkeydb_helper wrote: Sat Oct 05, 2024 7:25 amYes, download and extract the latest keydb fileianfrancorchamps wrote: Sat Oct 05, 2024 7:13 amThank you, should I download the latest keydb.cfg file?keydb_helper wrote: Sat Oct 05, 2024 6:53 am
Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
viewtopic.php?f=12&t=32784
ianfrancorchamps
Thanks mate, I'll give it a try sometimeCoopervid wrote: Sat Oct 05, 2024 10:25 am Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
