Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
ianfrancorchamps
Post by ianfrancorchamps » Fri Oct 04, 2024 3:48 am
MKB20_v77_88FU026_63C0.tgz
extranet
Re: Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
Post by extranet » Fri Oct 04, 2024 10:57 am
Excellent. My disc is hopefully coming in the next few days.
keydb_helper
Post by keydb_helper » Sat Oct 05, 2024 6:53 am
ianfrancorchamps wrote: Fri Oct 04, 2024 3:48 am MKB20_v77_88FU026_63C0.tgz
The 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
ianfrancorchamps
Post by ianfrancorchamps » Sat Oct 05, 2024 7:13 am
keydb_helper wrote: Sat Oct 05, 2024 6:53 am
Thank you, should I download the latest keydb.cfg file?
keydb_helper
Post by keydb_helper » Sat Oct 05, 2024 7:25 am
ianfrancorchamps wrote: Sat Oct 05, 2024 7:13 am
Yes, download and extract the latest keydb file
KeyDB Priority List
ianfrancorchamps
Post by ianfrancorchamps » Sat Oct 05, 2024 10:18 am
keydb_helper wrote: Sat Oct 05, 2024 7:25 am
It worked perfectly. Thanks a lot for your hard work👍
Post by Coopervid » Sat Oct 05, 2024 10:25 am
Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
viewtopic.php?f=12&t=32784
ianfrancorchamps
Post by ianfrancorchamps » Sun Oct 06, 2024 4:34 am
Coopervid wrote: Sat Oct 05, 2024 10:25 am Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
Thanks mate, I'll give it a try sometime
