[WORKING] Dump submitted - Gemini Man 4K Italian
MKB20_v72_Gemini_Man_3397.tgz
Re: [WORKING] Dump submitted - Gemini Man 4K Italian
Confirmed now decrypting.
thesurprised1
Ripping Gemini Man 4K uhd
Just acquired the uk version of Gemini Man, trying to rip it using MakeMKV with the HP-BU40N drive. The disc just spins and not reading? I guess my drive is not compatible as this movie uses 60fps? Any advice or help greatly appreciated.
Re: Ripping Gemini Man 4K uhd
No issue is the disc or the drive being defective or dirty clean itthesurprised1 wrote: ↑Fri Oct 04, 2024 6:02 pmJust acquired the uk version of Gemini Man, trying to rip it using MakeMKV with the HP-BU40N drive. The disc just spins and not reading? I guess my drive is not compatible as this movie uses 60fps? Any advice or help greatly appreciated.
thesurprised1
Thanks, i have managed to get the drive reading the disc using a Zidoo Z9X 8k media player, but does not play presumably due to disc being encrypted.
I am trying to decrypt it using the latest version of Makemkv on a macbook pro but the disc just spins?
I will try another computer in the meantime and see how that goes.
thesurprised1
After some thought and movement, I tried my windows laptop… the disc took time to load in MakeMkv then started to analyse the disc. All good… not sure why it didnt work first time?
