Re: SDFtool Flasher
#1126 Post by Billycar11 » Wed Oct 02, 2024 2:50 am
Ludvik wrote: Tue Oct 01, 2024 5:26 pm hello all, I use dvdfab so i tried to flash my new LGns55 to LGns60_1.00_bin and got error code: 0x82052603.
Any suggestion, please help...
follow the guide below flashing sequence if its not follow it wont work.
i made it for a reason guys... please read it this has been asked to many times
blake
Re: SDFtool Flasher
#1127 Post by blake » Fri Oct 04, 2024 5:13 pm
Hi guys!
I purchased an LG BP50NB40 NB52, and followed the instructions to flash and cross flash. But it would not read any BD or UHD BD disc. So I tried to flash another version and attempt recovery, but at this point it seems to be bricked as the tray will not open now, and I get error 0xff05c103. MakeMKV shows No disk and the tray open. When I try to write or recover, it finishes fast 'Done' but doesn't seem to do anything.
BD Drive shows: HL-DT-ST_BD-RE_BP50NB40_1.00_211409031732_XXXXXXXXXX
MakeMKV BETA 1.17.7:
OS device name: G:
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: XXXXXXXXXXX
Firmware date: 2114-09-03 17:32
Firmware version: 1.00
Any suggestions are appreciated!
Re: SDFtool Flasher
#1128 Post by Billycar11 » Fri Oct 04, 2024 9:16 pm
blake wrote: Fri Oct 04, 2024 5:13 pm Hi guys!
OS device name: G:
Revision: 1.00
Email me I may be able to help you unbrick it
erizock
Re: SDFtool Flasher
#1129 Post by erizock » Mon Oct 07, 2024 1:38 am
erizock wrote: Thu May 16, 2024 12:37 am Yes! It seemed to have worked!!!...
Last login: Wed May 15 07:45:37 on ttys000
ericober@Erics-MacBook-Pro ~ % cd /Applications/MakeMKV.app/Contents/MacOS
ericober@Erics-MacBook-Pro MacOS % ./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/4C20AED2
ASUS_BW-16D1HT_3.11_212012011759_KLZNBHD4945
ericober@Erics-MacBook-Pro MacOS % ./makemkvcon f -d '/IOBDServices/4C20AED2' -f '/Users/ericober/Desktop/ASUS firmware/sdf.bin' rawflash enc -i '/Users/ericober/Desktop/ASUS firmware/DE_ASUS_BW-16D1HT_3.10_MK.bin'
Reading input file /Users/ericober/Desktop/ASUS firmware/DE_ASUS_BW-16D1HT_3.10_MK.bin
Current Drive ID: ASUS_BW-16D1HT_3.11_212012011759_KLZNBHD4945
yes
100% Operation finished
Program Flash NG 06/29/00
Command produced error code 0x82062900
I don't have worry about this error code, right? "Command produced error code 0x82062900"
BIG THANKS TO TO d00zah, dcoke22, and of course MartyMCNuts. Appreciate this community helping a newbie. Now to get ripping!
Hi again-
Well, everything worked until last night, and now the drive doesn't read discs of any type. Every time I load a disc (be it DVD, BD or UHD) it spins for 10 seconds and then says there is "No disc". I am on Mac and have used Terminal commands (see my last post from May up above). Please help @d00zah, @dcoke22, and of course @MartyMCNuts!
Re: SDFtool Flasher
#1130 Post by Billycar11 » Mon Oct 07, 2024 1:41 am
erizock wrote: Mon Oct 07, 2024 1:38 am
Hi again-
this is very common for lg/asus drives this is why pioneers are the recommended drives.
pull power for a min then reconnect and try again reboot pc to it that dont work after 2 times its dead
rimmi2002
Re: SDFtool Flasher
#1131 Post by rimmi2002 » Wed Oct 09, 2024 2:19 am
Hi I am trying to Flash my LG BD-RE WH14NS40 drive to rip 4K DVDs. The drive is installed on PC running windows 10. Internal Drive. My current drive firmware is 1.03.
I read through the forums.
1. Downloaded SDFtool Flashes 1.3.5 to flash HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
I am having a few issues and was wondering if someone can help.
1. When I launch SDFtool the window is all scrunched up. I can see MT1959 text and encrypted txt but can't see its status. When I click the Read or write button I get the following error: "The Drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed. Under MakerMKV it shows the platform at MT1939. So is this drive not patchable?
Thanks.
Re: SDFtool Flasher
#1132 Post by d00zah » Wed Oct 09, 2024 1:54 pm
rimmi2002 wrote: Wed Oct 09, 2024 2:19 am I am having a few issues and was wondering if someone can help.
Thanks.
viewtopic.php?p=114370#p114370
cebefunk
Re: SDFtool Flasher
#1133 Post by cebefunk » Tue Oct 29, 2024 2:54 pm
I have LG WH16NS60. I want to flash the 1.02 MK on it.
I have issues with sdf Tool. When I read Firmware it creates an empty folder.
When I want to write simply nothing is happening.
What I'm doing wrong? Can somebody help me pls?
Screenshot 2024-10-29 154501.png (39.91 KiB) Viewed 9987 times
htown
Re: SDFtool Flasher
#1134 Post by htown » Wed Nov 06, 2024 11:30 pm
Got this drive Buffalo BRUHD-PU3-BK today and used your tool and firmware and it worked great.
Thank you.
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU12
Serial number: [redacted]
Firmware date: 2119-02-23 09:22
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 0.BU12O
Disc Information
Label: BLACK_HAWK_DOWN
Timestamp: 2019-03-20 16:24:08
Protection: AACS2.0/C v68
Data capacity: 84.41 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
igory2000
Re: SDFtool Flasher
#1135 Post by igory2000 » Thu Nov 07, 2024 7:07 am
Hello. My SDFtool Flasher does not see optical drives. Win 7x64, Net Framework 4.7.2 MakeMKV 1.16.5. Or do you necessarily need Win 10x64? Or it's something else, please help.
igory2000
Re: SDFtool Flasher
#1136 Post by igory2000 » Thu Nov 07, 2024 7:26 am
Here's what SDFtool Flasher writes
(база кода):
-----------------_Requested registry access is not allowed.   at Microsoft.Win32.RegistryKey.InternalOpenSubKeyCore(String name, Boolean writable)   at Microsoft.Win32.RegistryKey.OpenSubKey(String name, Boolean writable)   at Microsoft.Win32.RegistryKey.OpenSubKey(String name)   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)   at System.Windows.Forms.Form.OnLoad(EventArgs e)   at System.Windows.Forms.Form.OnCreateControl()   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)   at System.Windows.Forms.Control.CreateControl()   at System.Windows.Forms.Control.WmShowWindow(Message& m)   at System.Windows.Forms.Control.WndProc(Message& m)   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)   at System.Windows.Forms.ContainerControl.WndProc(Message& m)   at System.Windows.Forms.Form.WmShowWindow(Message& m)   at System.Windows.Forms.Form.WndProc(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)______________ Загруженные сборки ______________System.Private.CoreLib    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------SDFtool Flasher    Версия сборки_ 1.3.5.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Runtime    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Windows.Forms    Версия сборки_ 6.0.2.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Windows.Forms.Primitives    Версия сборки_ 6.0.2.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.ComponentModel.Primitives    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Runtime.InteropServices    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Drawing.Primitives    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Collections.Specialized    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Drawing.Common    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Threading    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Diagnostics.TraceSource    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Collections    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Diagnostics.Process    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.Primitives    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.ComponentModel.EventBasedAsync    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Threading.Thread    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------Accessibility    Версия сборки_ 4.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.ComponentModel.TypeConverter    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Numerics.Vectors    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Memory    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.ComponentModel    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Resources.Extensions    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Drawing    Версия сборки_ 6.0.2.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.ObjectModel    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Linq    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Runtime.Serialization.Formatters    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Collections.Concurrent    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------mscorlib    Версия сборки_ 4.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.SystemEvents    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Collections.NonGeneric    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Configuration.ConfigurationManager    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Runtime.InteropServices.RuntimeInformation    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Private.Uri    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Security.Cryptography.Algorithms    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Security.Cryptography.Primitives    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Xml.ReaderWriter    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Private.Xml    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Text.RegularExpressions    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Net.WebClient    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Text.Encoding.Extensions    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Xml.XmlSerializer    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.Registry    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Runtime.Loader    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Windows.Forms.resources    Версия сборки_ 6.0.2.0    Версия Win32_ неприменимо    CodeBase (база кода)_ ----------------------------------------System.Diagnostics.StackTrace    Версия сборки_ 6.0.0.0    Версия Win32_ неприменимо    CodeBase-----------------------
System.Reflection.Metadata
    Версия сборки: 6.0.0.0
    Версия Win32: неприменимо
    CodeBase (база кода):
System.Collections.Immutable
************** Оперативная отладка (JIT) **************
Re: SDFtool Flasher
#1137 Post by MartyMcNuts » Fri Nov 08, 2024 11:02 pm
igory2000 wrote: Thu Nov 07, 2024 7:07 am Hello. My SDFtool Flasher does not see optical drives. Win 7x64, Net Framework 4.7.2 MakeMKV 1.16.5. Or do you necessarily need Win 10x64? Or it's something else, please help.
Not compatible with Win7. Win 10 x64 and Win 11 x64 required. Did you not read the requirements?? Also, make sure you are running as admin.
jonghotti
Re: SDFtool Flasher
#1138 Post by jonghotti » Sat Nov 09, 2024 5:05 am
Hi again-
It happens from time to time.
Disconnect power and data connections to the drive and let it sit for 24 hours.
Then reconnect and it should be fine.
Don't believe the Pioneer hype. The ASUS is the best drive there is!
5tiffler
Re: SDFtool Flasher
#1139 Post by 5tiffler » Thu Nov 14, 2024 8:28 pm
Hi everyone. I'm new here. found a video about updating drives to read 4k blu ray. I'm not a massively tech minded person but i try my best with things. Ive got a Blu ray drive (i believe its a bdxl drive) which i would like to perhaps update to read 4k discs. However the tool comes back with an error code when i try it. the drive is
HL-DT-ST_BDDVDRW_UH12NS40_1.01_211711231550_S1K9SG8OG562
The Error code when trying to patch to WH16 1.02 as per the first page od this thread is 0x82052400
Any help as to if this drive can be patched or not and what i may be doing wrong would be great.
The drive is fitted to an external USB3 enclosure if that helps any.
Re: SDFtool Flasher
#1140 Post by MartyMcNuts » Thu Nov 14, 2024 9:23 pm
5tiffler wrote: Thu Nov 14, 2024 8:28 pm Hi everyone. I'm new here. found a video about updating drives to read 4k blu ray. I'm not a massively tech minded person but i try my best with things. Ive got a Blu ray drive (i believe its a bdxl drive) which i would like to perhaps update to read 4k discs. However the tool comes back with an error code when i try it. the drive is
Your enclosure might be the issue. What model is it?
Are you trying to flash WH16NS60 1.02-MK or WH16NS40 1.02? It should be the former.
