blake
Re: SDFtool Flasher
Hi guys!
I purchased an LG BP50NB40 NB52, and followed the instructions to flash and cross flash. But it would not read any BD or UHD BD disc. So I tried to flash another version and attempt recovery, but at this point it seems to be bricked as the tray will not open now, and I get error 0xff05c103. MakeMKV shows No disk and the tray open. When I try to write or recover, it finishes fast 'Done' but doesn't seem to do anything.
BD Drive shows: HL-DT-ST_BD-RE_BP50NB40_1.00_211409031732_XXXXXXXXXX
MakeMKV BETA 1.17.7:
OS device name: G:
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: XXXXXXXXXXX
Firmware date: 2114-09-03 17:32
Firmware version: 1.00
Any suggestions are appreciated!
OS device name: G:
Revision: 1.00
Re: SDFtool Flasher
Email me I may be able to help you unbrick itblake wrote: Fri Oct 04, 2024 5:13 pm Hi guys!
OS device name: G:
Revision: 1.00
erizock
Re: SDFtool Flasher
Hi again-erizock wrote: Thu May 16, 2024 12:37 am Yes! It seemed to have worked!!!...
Last login: Wed May 15 07:45:37 on ttys000
ericober@Erics-MacBook-Pro ~ % cd /Applications/MakeMKV.app/Contents/MacOS
ericober@Erics-MacBook-Pro MacOS % ./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/4C20AED2
ASUS_BW-16D1HT_3.11_212012011759_KLZNBHD4945
ericober@Erics-MacBook-Pro MacOS % ./makemkvcon f -d '/IOBDServices/4C20AED2' -f '/Users/ericober/Desktop/ASUS firmware/sdf.bin' rawflash enc -i '/Users/ericober/Desktop/ASUS firmware/DE_ASUS_BW-16D1HT_3.10_MK.bin'
Reading input file /Users/ericober/Desktop/ASUS firmware/DE_ASUS_BW-16D1HT_3.10_MK.bin
Current Drive ID: ASUS_BW-16D1HT_3.11_212012011759_KLZNBHD4945
yes
100% Operation finished
Program Flash NG 06/29/00
Command produced error code 0x82062900
I don't have worry about this error code, right? "Command produced error code 0x82062900"
BIG THANKS TO TO d00zah, dcoke22, and of course MartyMCNuts. Appreciate this community helping a newbie. Now to get ripping!
Well, everything worked until last night, and now the drive doesn't read discs of any type. Every time I load a disc (be it DVD, BD or UHD) it spins for 10 seconds and then says there is "No disc". I am on Mac and have used Terminal commands (see my last post from May up above). Please help @d00zah, @dcoke22, and of course @MartyMCNuts!
Re: SDFtool Flasher
this is very common for lg/asus drives this is why pioneers are the recommended drives.erizock wrote: Mon Oct 07, 2024 1:38 am
Hi again-
pull power for a min then reconnect and try again reboot pc to it that dont work after 2 times its dead
rimmi2002
Re: SDFtool Flasher
Hi I am trying to Flash my LG BD-RE WH14NS40 drive to rip 4K DVDs. The drive is installed on PC running windows 10. Internal Drive. My current drive firmware is 1.03.
I read through the forums.
1. Downloaded SDFtool Flashes 1.3.5 to flash HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
I am having a few issues and was wondering if someone can help.
1. When I launch SDFtool the window is all scrunched up. I can see MT1959 text and encrypted txt but can't see its status. When I click the Read or write button I get the following error: "The Drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed. Under MakerMKV it shows the platform at MT1939. So is this drive not patchable?
Thanks.
Thanks.
Re: SDFtool Flasher
rimmi2002 wrote: Wed Oct 09, 2024 2:19 am I am having a few issues and was wondering if someone can help.
Thanks.
viewtopic.php?p=114370#p114370
cebefunk
Re: SDFtool Flasher
I have LG WH16NS60. I want to flash the 1.02 MK on it.
I have issues with sdf Tool. When I read Firmware it creates an empty folder.
When I want to write simply nothing is happening.
What I'm doing wrong? Can somebody help me pls?
htown
Re: SDFtool Flasher
Got this drive Buffalo BRUHD-PU3-BK today and used your tool and firmware and it worked great.
Thank you.
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU12
Serial number: [redacted]
Firmware date: 2119-02-23 09:22
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 0.BU12O
Disc Information
Label: BLACK_HAWK_DOWN
Timestamp: 2019-03-20 16:24:08
Protection: AACS2.0/C v68
Data capacity: 84.41 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Thank you.
OS device name: E:
Revision: BU12
Disc Information
Number of layers: 3
igory2000
Re: SDFtool Flasher
Hello. My SDFtool Flasher does not see optical drives. Win 7x64, Net Framework 4.7.2 MakeMKV 1.16.5. Or do you necessarily need Win 10x64? Or it's something else, please help.
igory2000
Re: SDFtool Flasher
Here's what SDFtool Flasher writes
(база кода):
-----------------_Requested registry access is not allowed. at Microsoft.Win32.RegistryKey.InternalOpenSubKeyCore(String name, Boolean writable) at Microsoft.Win32.RegistryKey.OpenSubKey(String name, Boolean writable) at Microsoft.Win32.RegistryKey.OpenSubKey(String name) at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation() at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)______________ Загруженные сборки ______________System.Private.CoreLib Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------SDFtool Flasher Версия сборки_ 1.3.5.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Runtime Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Windows.Forms Версия сборки_ 6.0.2.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Windows.Forms.Primitives Версия сборки_ 6.0.2.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.ComponentModel.Primitives Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Runtime.InteropServices Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Drawing.Primitives Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Collections.Specialized Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Drawing.Common Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Threading Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Diagnostics.TraceSource Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Collections Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Diagnostics.Process Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.Primitives Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.ComponentModel.EventBasedAsync Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Threading.Thread Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------Accessibility Версия сборки_ 4.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.ComponentModel.TypeConverter Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Numerics.Vectors Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Memory Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.ComponentModel Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Resources.Extensions Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Drawing Версия сборки_ 6.0.2.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.ObjectModel Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Linq Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Runtime.Serialization.Formatters Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Collections.Concurrent Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------mscorlib Версия сборки_ 4.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.SystemEvents Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Collections.NonGeneric Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Configuration.ConfigurationManager Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Runtime.InteropServices.RuntimeInformation Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Private.Uri Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Security.Cryptography.Algorithms Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Security.Cryptography.Primitives Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Xml.ReaderWriter Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Private.Xml Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Text.RegularExpressions Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Net.WebClient Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Text.Encoding.Extensions Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Xml.XmlSerializer Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------Microsoft.Win32.Registry Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Runtime.Loader Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Windows.Forms.resources Версия сборки_ 6.0.2.0 Версия Win32_ неприменимо CodeBase (база кода)_ ----------------------------------------System.Diagnostics.StackTrace Версия сборки_ 6.0.0.0 Версия Win32_ неприменимо CodeBase-----------------------
System.Reflection.Metadata
Версия сборки: 6.0.0.0
Версия Win32: неприменимо
CodeBase (база кода):
System.Collections.Immutable
************** Оперативная отладка (JIT) **************-
Re: SDFtool Flasher
Not compatible with Win7. Win 10 x64 and Win 11 x64 required. Did you not read the requirements?? Also, make sure you are running as admin.igory2000 wrote: Thu Nov 07, 2024 7:07 am Hello. My SDFtool Flasher does not see optical drives. Win 7x64, Net Framework 4.7.2 MakeMKV 1.16.5. Or do you necessarily need Win 10x64? Or it's something else, please help.
jonghotti
Re: SDFtool Flasher
It happens from time to time.Hi again-
Disconnect power and data connections to the drive and let it sit for 24 hours.
Then reconnect and it should be fine.
Don't believe the Pioneer hype. The ASUS is the best drive there is!
5tiffler
Re: SDFtool Flasher
Hi everyone. I'm new here. found a video about updating drives to read 4k blu ray. I'm not a massively tech minded person but i try my best with things. Ive got a Blu ray drive (i believe its a bdxl drive) which i would like to perhaps update to read 4k discs. However the tool comes back with an error code when i try it. the drive is
HL-DT-ST_BDDVDRW_UH12NS40_1.01_211711231550_S1K9SG8OG562
The Error code when trying to patch to WH16 1.02 as per the first page od this thread is 0x82052400
Any help as to if this drive can be patched or not and what i may be doing wrong would be great.
The drive is fitted to an external USB3 enclosure if that helps any.
Re: SDFtool Flasher
Your enclosure might be the issue. What model is it?5tiffler wrote: Thu Nov 14, 2024 8:28 pm Hi everyone. I'm new here. found a video about updating drives to read 4k blu ray. I'm not a massively tech minded person but i try my best with things. Ive got a Blu ray drive (i believe its a bdxl drive) which i would like to perhaps update to read 4k discs. However the tool comes back with an error code when i try it. the drive is
Are you trying to flash WH16NS60 1.02-MK or WH16NS40 1.02? It should be the former.
Ekontos
Re: SDFtool Flasher Problem
My drive info. It is an LG BP60NB10. It looks like it flashed successfully. I used this bin: DE_LG_BP60NB10-NB12_1.02-MK.bin
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Label: SNATCH
Timestamp: 2021-04-22 18:17:18
Protection: AACS2.0/C v76
Data capacity: 89.95 Gb
Number of layers: 3
I still get errors when trying to Rip a blu-ray disk. Here is a summary:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Any suggestions on how to get past this? thanks.
Revision: 1.02
Serial number:
Disc Information
Label: SNATCH
Number of layers: 3
