Failed to save title
justauser
Post by justauser »
I'm making .mkv files from my DVD .iso images.
I'm stuck at one DVD with the same error. The file has exactly 919.0 MB. It gets stuck everytime at 325.4 MB.
Here is the log:
MakeMKV v1.6.14 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Rafael/MakeMKV_log.txt
Opening files on harddrive at C:/Users/Rafael/Desktop/MainMovie/CDZ 04/VIDEO_TS/
Title #0 was added (1 cell(s), 0:23:39)
DEBUG: Code 233 at XMP2yfpBXSxxbj+o2pX+eaaC:0
Saving 1 titles into directory C:/Users/Rafael/Desktop
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 224 at ;{p6l"9*LJqc{A_Vm5Tp5-:213129823
DEBUG: Code 754 at WtF#"'***TGp@"|krRB"4:213133250
DEBUG: Code 2025 at WtF#"'***TGp@"|krRB"4:213133250
DEBUG: Code 1581 at WtF#"'***TGp@"|krRB"4:213133250
DEBUG: Code 324324000 at Nj[LCO1mSqvr%Sj}b@(:29393608
DEBUG: Code 12 at Nj[LCO1mSqvr%Sj}b@(:213134952
DEBUG: Code 149 at Nj[LCO1mSqvr%Sj}b@(:29398553
DEBUG: Code 6 at Nj[LCO1mSqvr%Sj}b@(:29398576
DEBUG: Code 0 at WtF#"'***TGp@"|krRB"4:213134377
Failed to save title 0 to file C:/Users/Rafael/Desktop/title00.mkv
0 titles saved, 1 failed
It works with every DVD I try but this. Just in case if someone needs it, these are my PC specifications:
Windows 7 Ultimate (x64)
1.36 TB HD
Intel Core 2 Duo E7400 2.80 GHz
4.00 GB of RAM
GeForce GTS 250 - 512 MB
setarip_old
Re: Failed to save title
Post by setarip_old »
Hi!
Instead of using the .ISO image file for input, try using your original, commercial DVD as your source, DIRECTLY with MakeMKV...
justauser
Post by justauser »
setarip_old wrote:Hi!
I just tried your tip and just got the same problem. Thanks anyway.
setarip_old
I just noticed that you've indicated that your .ISO is only 919MB.
What is the Title, Region Number, and total size of your original, commercial DVD?
justauser
Post by justauser »
setarip_old wrote:What is the Title, Region Number, and total size of your original, commercial DVD?
Title: Cavaleiros do Zod?aco (Saint Seiya)
Region: 4
setarip_old
As you did in your first post to this thread, please post the debug log for your attempt to use MakeMKV with your ORIGINAL DVD of 3.7Gb. (If you haven't saved it, please do so now)...
justauser
Post by justauser »
setarip_old wrote:(...) please post the debug log for your attempt to use MakeMKV with your ORIGINAL DVD of 3.7Gb. (If you haven't saved it, please do so now)...
Here it is:
Title #0 was added (1 cell(s), 0:23:38)
Title #1 was added (1 cell(s), 0:23:39)
Title #2 was added (1 cell(s), 0:23:38)
Title #3 was added (1 cell(s), 0:23:39)
Title #4 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at Gx/Z1WELoNwOI2WfRuEJGHoU:0
Failed to save title 3 to file C:/Users/Rafael/Desktop/t03_Disco_04.mkv
justauser
Post by justauser »
anyone...?
Post by mike admin »
shuold be fixed in 1.6.15
justauser
Post by justauser »
mike admin wrote:shuold be fixed in 1.6.15
I'm still having the same problem. T_T
Please send the FULL log ( one written by MakeMKV to C:\Users\Rafael/MakeMKV_log.txt ) to support@makemkv.com - it should have additional information for troubleshooting.
