Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
ianfrancorchamps
Post by ianfrancorchamps »
MKB20_v77_88FU026_63C0.tgz
extranet
Re: Dump Submitted: Tai Chi Master 4K UHD disc (63C0)
Post by extranet »
Excellent. My disc is hopefully coming in the next few days.
keydb_helper
Post by keydb_helper »
ianfrancorchamps wrote: Fri Oct 04, 2024 3:48 am MKB20_v77_88FU026_63C0.tgz
The 63C0 release of Tai Chi Master with disc ID 0x645118BAA0A601D79EADF57A03FC9B20B2F92F53 has been added to the public keydb. It should work with your disc
Public KeyDB Disc Submissions
ianfrancorchamps
keydb_helper wrote: Sat Oct 05, 2024 6:53 am
Thank you, should I download the latest keydb.cfg file?
keydb_helper
ianfrancorchamps wrote: Sat Oct 05, 2024 7:13 am
Yes, download and extract the latest keydb file
ianfrancorchamps
keydb_helper wrote: Sat Oct 05, 2024 7:25 am
It worked perfectly. Thanks a lot for your hard work👍
Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
viewtopic.php?f=12&t=32784
ianfrancorchamps
Coopervid wrote: Sat Oct 05, 2024 10:25 am Don't downlad the whole keydb.cfg each and every time. Follow this and the synchronize process will run very fast and just update the database.
Thanks mate, I'll give it a try sometime
