Recommendation for best (most reliable and versatile) LibreDrive for 2024?
CalicoSkies
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
#436 Post by CalicoSkies » Wed Oct 02, 2024 7:13 pm
Coopervid wrote:
Wed Oct 02, 2024 6:39 pm
CalicoSkies wrote:
Wed Oct 02, 2024 4:45 pm
Coopervid wrote:
Wed Oct 02, 2024 2:54 pm
Tell me when it's supposed to arrive.
Amazon says it should arrive on October 8
Check your PM.
Thanks. I'll try it when the drive arrives & I get it installed in my PC.
DavoBR
#437 Post by DavoBR » Wed Oct 02, 2024 8:42 pm
Coopervid wrote:
Wed Oct 02, 2024 1:09 pm
DavoBR wrote:
Wed Oct 02, 2024 12:43 pm
Is there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
https://www.amazon.co.uk/BDR-212V-Blu-r ... B08R89FN61
It has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.
Daft question... is there an external drive equivalent?
#438 Post by Coopervid » Wed Oct 02, 2024 9:00 pm
Tell me your country of residence.
DavoBR
#439 Post by DavoBR » Thu Oct 03, 2024 6:57 am
UK
#440 Post by Coopervid » Thu Oct 03, 2024 9:48 am
UK
Buy the Verbatim 43888 on Amazon. It is an UD04 will work out of the box. The enclosure is power hungry. You should use an USB-C port or make sure it gets enough power from an USB-A port. A powered hub will also help.
#441 Post by MartyMcNuts » Thu Oct 03, 2024 9:50 am
No but you can put it in a Vantec DX2 enclosure.
bootcheck
#442 Post by bootcheck » Thu Oct 03, 2024 12:51 pm
Coopervid wrote:
Fri Sep 20, 2024 5:27 pm
bootcheck wrote:
Thu Sep 19, 2024 6:03 pm
Coopervid wrote:
Thu Sep 19, 2024 4:47 pm
Try to get the Vinpower 212V. Maybe from Amazon.de. I didn‘t find it in Poland.
Found it on AMZN.de, but they won't ship to PL.
Any alternatives?
Would it handle UHD?
Try ubuy.com.pl. It needs to be flashed. Tell me when you have it.
I've got VinPower 212V. Running Linux.
Would you kindly share flashing instructions?
#443 Post by Coopervid » Thu Oct 03, 2024 1:20 pm
Any alternatives?
PM sent.
DavoBR
#444 Post by DavoBR » Thu Oct 03, 2024 7:15 pm
UK
miki_mouse
#445 Post by miki_mouse » Thu Oct 03, 2024 8:34 pm
Hello @coopervid, I'm from Italy. It's possible to have support for best libredrive ? I read some post on forum and usterstand that Pioneer BDR-212 V is good for start viewtopic.php?t=33192 (I'm newbie :roll: ) I'm interessed for 5.25" internal thanks
#446 Post by Coopervid » Fri Oct 04, 2024 12:01 am
https://www.amazon.it/Vinpower-Digital- ... C76&sr=8-1
Buy it and post when it is supposed to arrive.
miki_mouse
#447 Post by miki_mouse » Fri Oct 04, 2024 6:08 am
Ok, I update you.. should arrive next week
#448 Post by Coopervid » Fri Oct 04, 2024 10:01 am
PM sent.
differentiate
#449 Post by differentiate » Sat Oct 05, 2024 8:08 am
Hi, I followed your advice and ordered a Vinpower BDR 212V, which will arrive Monday. Any help or guidance to enable libredrive is much appreciated.
nicktenn
#450 Post by nicktenn » Sat Oct 05, 2024 3:31 pm
Just want to confirm that the drives sold here with flashed firmware will work fine in a dx2 on a Mac Studio running makemkv right?
