Thanks. I'll try it when the drive arrives & I get it installed in my PC.
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Daft question... is there an external drive equivalent?Coopervid wrote: ↑Wed Oct 02, 2024 1:09 pmIt has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.DavoBR wrote: ↑Wed Oct 02, 2024 12:43 pmIs there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
https://www.amazon.co.uk/BDR-212V-Blu-r ... B08R89FN61
Tell me your country of residence.DavoBR wrote: ↑Wed Oct 02, 2024 8:42 pmDaft question... is there an external drive equivalent?Coopervid wrote: ↑Wed Oct 02, 2024 1:09 pmIt has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.DavoBR wrote: ↑Wed Oct 02, 2024 12:43 pmIs there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
Buy the Verbatim 43888 on Amazon. It is an UD04 will work out of the box. The enclosure is power hungry. You should use an USB-C port or make sure it gets enough power from an USB-A port. A powered hub will also help.
No but you can put it in a Vantec DX2 enclosure.DavoBR wrote: ↑Wed Oct 02, 2024 8:42 pmDaft question... is there an external drive equivalent?Coopervid wrote: ↑Wed Oct 02, 2024 1:09 pmIt has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.DavoBR wrote: ↑Wed Oct 02, 2024 12:43 pmIs there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
Hello @coopervid, I'm from Italy. It's possible to have support for best libredrive ? I read some post on forum and usterstand that Pioneer BDR-212 V is good for start viewtopic.php?t=33192 (I'm newbie
) I'm interessed for 5.25" internal thanks
https://www.amazon.it/Vinpower-Digital- ... C76&sr=8-1miki_mouse wrote: ↑Thu Oct 03, 2024 8:34 pmHello @coopervid, I'm from Italy. It's possible to have support for best libredrive ? I read some post on forum and usterstand that Pioneer BDR-212 V is good for start viewtopic.php?t=33192 (I'm newbie) I'm interessed for 5.25" internal thanks
Buy it and post when it is supposed to arrive.
Ok, I update you.. should arrive next week
Hi, I followed your advice and ordered a Vinpower BDR 212V, which will arrive Monday. Any help or guidance to enable libredrive is much appreciated.
Just want to confirm that the drives sold here with flashed firmware will work fine in a dx2 on a Mac Studio running makemkv right?
