Recommendation for best (most reliable and versatile) LibreDrive for 2024?
CalicoSkies
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Post by CalicoSkies »
Coopervid wrote: Wed Oct 02, 2024 6:39 pm
CalicoSkies wrote: Wed Oct 02, 2024 4:45 pm
Coopervid wrote: Wed Oct 02, 2024 2:54 pm
Tell me when it's supposed to arrive.
Amazon says it should arrive on October 8
Check your PM.
Thanks. I'll try it when the drive arrives & I get it installed in my PC.
DavoBR
Post by DavoBR »
Coopervid wrote: Wed Oct 02, 2024 1:09 pm
DavoBR wrote: Wed Oct 02, 2024 12:43 pm Is there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
https://www.amazon.co.uk/BDR-212V-Blu-r ... B08R89FN61
It has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.
Daft question... is there an external drive equivalent?
DavoBR wrote: Wed Oct 02, 2024 8:42 pm
Tell me your country of residence.
DavoBR
Post by DavoBR »
Coopervid wrote: Wed Oct 02, 2024 9:00 pm
UK
DavoBR wrote: Thu Oct 03, 2024 6:57 am
UK
Buy the Verbatim 43888 on Amazon. It is an UD04 will work out of the box. The enclosure is power hungry. You should use an USB-C port or make sure it gets enough power from an USB-A port. A powered hub will also help.
No but you can put it in a Vantec DX2 enclosure.
bootcheck
Post by bootcheck »
Coopervid wrote: Fri Sep 20, 2024 5:27 pm
bootcheck wrote: Thu Sep 19, 2024 6:03 pm
Coopervid wrote: Thu Sep 19, 2024 4:47 pm
Try to get the Vinpower 212V. Maybe from Amazon.de. I didn‘t find it in Poland.
Found it on AMZN.de, but they won't ship to PL.
Any alternatives?
Would it handle UHD?
Try ubuy.com.pl. It needs to be flashed. Tell me when you have it.
I've got VinPower 212V. Running Linux.
Would you kindly share flashing instructions?
bootcheck wrote: Thu Oct 03, 2024 12:51 pm
Any alternatives?
PM sent.
DavoBR
Post by DavoBR »
Coopervid wrote: Thu Oct 03, 2024 9:48 am
UK
miki_mouse
Post by miki_mouse »
Hello @coopervid, I'm from Italy. It's possible to have support for best libredrive ? I read some post on forum and usterstand that Pioneer BDR-212 V is good for start viewtopic.php?t=33192 (I'm newbie :roll: ) I'm interessed for 5.25" internal thanks
miki_mouse wrote: Thu Oct 03, 2024 8:34 pm Hello @coopervid, I'm from Italy. It's possible to have support for best libredrive ? I read some post on forum and usterstand that Pioneer BDR-212 V is good for start viewtopic.php?t=33192 (I'm newbie :roll: ) I'm interessed for 5.25" internal thanks
https://www.amazon.it/Vinpower-Digital- ... C76&sr=8-1
Buy it and post when it is supposed to arrive.
miki_mouse
Ok, I update you.. should arrive next week
miki_mouse wrote: Fri Oct 04, 2024 6:08 am Ok, I update you.. should arrive next week
PM sent.
differentiate
Post by differentiate »
Hi, I followed your advice and ordered a Vinpower BDR 212V, which will arrive Monday. Any help or guidance to enable libredrive is much appreciated.
nicktenn
Post by nicktenn »
Just want to confirm that the drives sold here with flashed firmware will work fine in a dx2 on a Mac Studio running makemkv right?
