Hello everyone,
I recently purchased an Archgon Model: MD-8107-U3 and after reading the forums it appears the drive inside is an LG BU40N. I downloaded the SDF Tool Flasher in the "Downgrade Enabled Firmware V.2" and "The all you need firmware pack" I tried to use the tool and flash it to the one labeled "LG Slim BU40N" But I keep getting an error of "Check Sum is Mismatched. Drive will go to BOOT Mode. Please try again." Any ideas how to get it to work, or am I doing something wrong? Thank you in advance.
LG BU40 N Issues
Re: LG BU40 N Issues
Follow the guide below and don't use that old flasher your trying to use
Hello. I tried to use the one listed in the guide and it said successful, but when I tried to copy the disk (4K The Fifth Element) it read it and errored out while trying to copy.
The error on VLC when viewing it is:
Blu-ray error:
This Blu-ray Disc needs a library for AACS decoding, and your system does not have it.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///D:\'. Check the log for details.
The error on the copy is:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '22870093824'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '22870093824'
Failed to save title 0 to file E:/Media Backup/The Fifth Element/Fifth Element_t00.mkv
0 titles saved, 1 failed
Now it will not read the disk at all in MKV. Any ideas on what I did wrong?
Information if needed:
Product: BD-RE BU40N
Revision: 1.03
Serial number: [redacted]
Highest AACS version: 76
Firmware version: 1.03
Disc Information
Disc is being loaded
Blu-ray error:
Revision: 1.03
Disc Information
After a reset it is working fine now. Not sure why it did that, but thank you!
