Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
#421 Post by Coopervid » Fri Sep 20, 2024 5:27 pm
bootcheck wrote:
Thu Sep 19, 2024 6:03 pm
Coopervid wrote:
Thu Sep 19, 2024 4:47 pm
bootcheck wrote:
Thu Sep 19, 2024 12:19 pm
Could you please recommend drive?
Media: Bluray, UHD 4K
Format: 5.25" internal bay
Country: Poland
Try to get the Vinpower 212V. Maybe from Amazon.de. I didn‘t find it in Poland.
Found it on AMZN.de, but they won't ship to PL.
Any alternatives?
Would it handle UHD?
Try ubuy.com.pl. It needs to be flashed. Tell me when you have it.
mjamm
#422 Post by mjamm » Tue Oct 01, 2024 12:43 am
Country: US
I got the vinpower pioneer BDR-212V from Amazon, it says it is LibreDrive possible, not yet enabled.
How can I flash it to enable LibreDrive?
Thanks in advance.
Country of Residence: US
I ordered the vinpower Pioneer BDR-212V from amazon, how do I go checking the firmware it has and flash it with a LibreDrive firmware?
Thx in advance.
#423 Post by Billycar11 » Tue Oct 01, 2024 1:42 am
Country: US
Thanks in advance.
email me or pm cooper
#424 Post by Coopervid » Tue Oct 01, 2024 9:21 am
Country: US
Thanks in advance.
PM sent.
mjamm
#425 Post by mjamm » Tue Oct 01, 2024 6:56 pm
Perfect, worked like a charm, Thx much Cooper.
Thx in advance.
CalicoSkies
#426 Post by CalicoSkies » Tue Oct 01, 2024 9:42 pm
I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
Earlier in this thread, I saw people mention the BDR-212V (https://www.amazon.com/Pioneer-BDR-212V ... 9FN61?th=1), but it looks like that doesn't rip 4K/UHD?
#427 Post by Coopervid » Tue Oct 01, 2024 9:57 pm
If you live in the US buy this drive and post again. I will send you what is needed to read UHD.
CalicoSkies
#428 Post by CalicoSkies » Tue Oct 01, 2024 11:39 pm
Does that mean it actually can read UHD? Is it just with a firmware update or something?
#429 Post by Coopervid » Wed Oct 02, 2024 8:32 am
With the right firmware it will read UHDs and can also read and write BD-XL.
DavoBR
#430 Post by DavoBR » Wed Oct 02, 2024 12:43 pm
Is there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
https://www.amazon.co.uk/BDR-212V-Blu-r ... B08R89FN61
#431 Post by Coopervid » Wed Oct 02, 2024 1:09 pm
It has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.
CalicoSkies
#432 Post by CalicoSkies » Wed Oct 02, 2024 2:49 pm
I just went ahead and ordered one of these Pioneer BDR-212V drives from Amazon
#433 Post by Coopervid » Wed Oct 02, 2024 2:54 pm
Tell me when it's supposed to arrive.
CalicoSkies
#434 Post by CalicoSkies » Wed Oct 02, 2024 4:45 pm
Amazon says it should arrive on October 8
#435 Post by Coopervid » Wed Oct 02, 2024 6:39 pm
Check your PM.
