Hi folks,
I am trying to clean up my user home directory on my Linux system.
And I am simply trying to change the location MakeMKV uses instead of ~/.MakeMKV/ as my user home is full of files that simply do not belong there, including the directory by MakeMKV.
I can see in the MakeMKV settings, that I can change the data directory, but that's not enough.
Most apps provide a environment variable that can be set, and it would be very nice if MakeMKV also has one.
Does anybody know something about that?
Thanks and have a nice day!
Env-Var to move ~/.MakeMKV/ directory?
segfaulted
Re: Env-Var to move ~/.MakeMKV/ directory?
The variable HOME will set the directory where .MakeMKV will be found. I don't think there's any way to change the name for .MakeMKV itself. A few other external libs also seem to reference that variable, so don't be surprised if other dot folders show up alongside it.
Makemkv doesn't need to pollute the environment. Try using a script to define HOME=/what/ever then start makemkv.
#!/bin/bash
mkdir -p /home/$USER/apps
HOME=/home/$USER/apps
makemkv-
W4tchT0wer
Thanks for your replies and sad to see that MakeMKV does not support such a simple thing.
I've opted for creating the wrapper script ~/.local/bin/makemkv and override $HOME in there. That way, my desktop shortcut etc. also works properly.
I haven't had any issues yet, but we'll see
#!/bin/sh
export HOME="${XDG_STATE_HOME:-$HOME/.local/state}"/makemkv
mkdir --parent "$HOME"
/usr/bin/makemkv
The convention of having . directories in $HOME (vs somewhere like .config) is over 50 years old. I would just leave well enough alone.W4tchT0wer wrote: ↑Tue Oct 01, 2024 6:13 pmAnd I am simply trying to change the location MakeMKV uses instead of ~/.MakeMKV/ as my user home is full of files that simply do not belong there, including the directory by MakeMKV.
W4tchT0wer
Well, it would be pretty easy to fix/improve ^^
A lot of applications allow you to provide a path via Env-Vars and I got rid of about 20 dot files/directories in my user-home with that.
Having apps use the correct location by-default would be better, but that's a valid workaround for me and very worth it.
Nothing would change for the better if we just stuck to conventions. There are many threads about the same general idea for a wide variety of apps, and many are using XDG base directories by default with $HOME as a fallback if they aren't defined. It would be nice to see makemkv do the same.bmillham wrote: ↑Wed Oct 09, 2024 8:12 pmThe convention of having . directories in $HOME (vs somewhere like .config) is over 50 years old. I would just leave well enough alone.W4tchT0wer wrote: ↑Tue Oct 01, 2024 6:13 pmAnd I am simply trying to change the location MakeMKV uses instead of ~/.MakeMKV/ as my user home is full of files that simply do not belong there, including the directory by MakeMKV.
https://specifications.freedesktop.org/ ... ec/latest/
georgesgiralt
Have you thought that if you move config directories from your home folder to another place, all users on the system will be forced to use YOUR settings ! (and see what they are ...)
Remember that Linux emanate from Unix which is a multi user system ....
W4tchT0wer
Hi,georgesgiralt wrote: ↑Fri Oct 17, 2025 9:05 amHello,
you seem to be misunderstanding. The config directory is still inside your $HOME, just in a sub-directory.
So for example $HOME/.config/makekmv/ or $HOME/.local/share/makemkv/
And even for users upgrading, MakeMKV could first check its old/current path and if it does not exist, it will start using the new directory.
