Curious noise level - ASUS BW-16D1X-U
00codefinder
Post by 00codefinder »
Hi all,
I have had the ASUS BW-16D1X-U drive for about 8 months, used when I first purchased it and then put it on a shelf. Took it back out to burn some media and noticed its loud when burning or even reading media. Is this normal, curious what others have noticed.
I also realized the drive can be flashed, so will definitely do that, but want to make sure the noise thing is normal, otherwise I'll exchange via my extended warranty.
Thanks all for your comments in advance.
00
Re: Curious noise level - ASUS BW-16D1X-U
whats the makemkv drive info section say
00codefinder
here's the info.
Current profile: BD-R SRM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: [redacted]
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 19
00codefinder wrote: Wed Oct 02, 2024 2:19 pm here's the info.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Yeah the LG ones are loud you have an LG rebrand to Asus.
The pioneers are quiet
