Try ubuy.com.pl. It needs to be flashed. Tell me when you have it.bootcheck wrote: Thu Sep 19, 2024 6:03 pmFound it on AMZN.de, but they won't ship to PL.
Any alternatives?
Would it handle UHD?
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Country: US
I got the vinpower pioneer BDR-212V from Amazon, it says it is LibreDrive possible, not yet enabled.
How can I flash it to enable LibreDrive?
Thanks in advance.
Thanks in advance.
Country of Residence: US
I ordered the vinpower Pioneer BDR-212V from amazon, how do I go checking the firmware it has and flash it with a LibreDrive firmware?
Thx in advance.
Thx in advance.
email me or pm coopermjamm wrote: Tue Oct 01, 2024 12:43 am Country: US
Thanks in advance.
PM sent.mjamm wrote: Tue Oct 01, 2024 12:43 am Country: US
Thanks in advance.
Perfect, worked like a charm, Thx much Cooper.
Thx in advance.
Thx in advance.
CalicoSkies
I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
Earlier in this thread, I saw people mention the BDR-212V (https://www.amazon.com/Pioneer-BDR-212V ... 9FN61?th=1), but it looks like that doesn't rip 4K/UHD?
If you live in the US buy this drive and post again. I will send you what is needed to read UHD.CalicoSkies wrote: Tue Oct 01, 2024 9:42 pm I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
CalicoSkies
Does that mean it actually can read UHD? Is it just with a firmware update or something?Coopervid wrote: Tue Oct 01, 2024 9:57 pmIf you live in the US buy this drive and post again. I will send you what is needed to read UHD.CalicoSkies wrote: Tue Oct 01, 2024 9:42 pm I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
With the right firmware it will read UHDs and can also read and write BD-XL.CalicoSkies wrote: Tue Oct 01, 2024 11:39 pmDoes that mean it actually can read UHD? Is it just with a firmware update or something?Coopervid wrote: Tue Oct 01, 2024 9:57 pmIf you live in the US buy this drive and post again. I will send you what is needed to read UHD.CalicoSkies wrote: Tue Oct 01, 2024 9:42 pm I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
Is there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
https://www.amazon.co.uk/BDR-212V-Blu-r ... B08R89FN61
It has old firmware and can still be flashed. And you could it return anyway since Amazon's return policy is really good.DavoBR wrote: Wed Oct 02, 2024 12:43 pm Is there any way to check on the player's firmware other than trying to ask other purchasers if they can check or buying the player and running MakeMKV?
CalicoSkies
I just went ahead and ordered one of these Pioneer BDR-212V drives from AmazonCoopervid wrote: Tue Oct 01, 2024 9:57 pmIf you live in the US buy this drive and post again. I will send you what is needed to read UHD.CalicoSkies wrote: Tue Oct 01, 2024 9:42 pm I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
Tell me when it's supposed to arrive.CalicoSkies wrote: Wed Oct 02, 2024 2:49 pmI just went ahead and ordered one of these Pioneer BDR-212V drives from AmazonCoopervid wrote: Tue Oct 01, 2024 9:57 pmIf you live in the US buy this drive and post again. I will send you what is needed to read UHD.CalicoSkies wrote: Tue Oct 01, 2024 9:42 pm I currently have a LG WH16NS40, but sometimes I run into trouble reading some discs, and I've also had an issue where the drive sometimes becomes inaccessible until I reboot (which seems to be a common issue). I'm considering buying a different drive, and I've heard the Pioneer drives are fairly good. I'd be interested in buying a Pioneer LibreDrive which can rip up to UHD/4K discs, but I'm not sure which model would support that. Ideally burning discs too, but honestly I rarely burn discs these days, so that's not a deal-breaker.
CalicoSkies
Amazon says it should arrive on October 8Coopervid wrote: Wed Oct 02, 2024 2:54 pmTell me when it's supposed to arrive.CalicoSkies wrote: Wed Oct 02, 2024 2:49 pmI just went ahead and ordered one of these Pioneer BDR-212V drives from AmazonCoopervid wrote: Tue Oct 01, 2024 9:57 pm
Check your PM.CalicoSkies wrote: Wed Oct 02, 2024 4:45 pmAmazon says it should arrive on October 8Coopervid wrote: Wed Oct 02, 2024 2:54 pmTell me when it's supposed to arrive.CalicoSkies wrote: Wed Oct 02, 2024 2:49 pm
