Hey!
I've been having some trouble ripping Fast and Furious 9 4k, every other disc I've been ripping seems to be working fine.
The normal bluray version of Fast and Furious 9 works fine.
Many other 4k movies have worked and ripped well, only other disc with trouble has been Men in Black which only rips at 2x speed but that seems to be unrelated.
Also, this is the second Fast and Furious 9 disc that hasn't been working.
Kind regards,
Melten.
Fast and Furious 9 UHD not registering on makemkv.
Re: Fast and Furious 9 UHD not registering on makemkv.
The standard instruction applies: Clean the disc before trying again.Melten wrote: ↑Mon Sep 30, 2024 5:54 pmHey!
Kind regards,
Melten.
I have already attempted that thanks!
Then replace the disc.
This is my second disc that didn't work tho?
Kind regards,
Melten
Kind regards,
Melten
Your options are:
1. Replace the disc
2. Try a different drive. (As silly as it sounds, it does happen occasionally that a drive just won't like a particular disc!)
Ahh, well thanks then!
I don't have a second drive so I hope that's not the case :O
Kind regards,
Melten.
Kind regards,
Melten.
