Friends 4K Decryption Keys
Pureness3768
I've never ripped 4K TV Shows until now. I was excited to get it all going until I realized that none of the discs have been decrypted and I would have to send that file to MakeMKV, but that's a ton of discs. Is there an easier way to go about this? Or am I going to just have to insert each disc, wait for it to fail and create the .tgz file and send it all to MakemKV? Let me know if you guys have different ideas on how to go about this more efficiently. Maybe someone out there is willing to bite the bullet and do all of that work haha!
Re: Friends 4K Decryption Keys
yeah you will have to do it all manually
but you can back it up with the encryption at the same time so you dont have to take them all out again just use the yellow folder on top and make sure the decrypt box is unchecked.(normally you want this checked for others reading)
then when the keys are added just open the index file in makemkv with the file open menu and it will be done in minutes
