Can't get Makemkv to run
robbo
#1 Post by robbo » Sun Sep 29, 2024 11:28 pm
Hi!
I am on Sequoia 15.0 on M1 iMac. I downloaded 17.7 code today and tried the beta key. It seems to accept the key and asked me to restart the program, but it sticks in a loop. It launches with the "application too old" popup message. Pressing register gives a Fatal warning popup. Pressing OK brings up the licensing popup with garbage in the key field and invalid in the type field. If I clear the clear the garbage out and enter the Beta key and press purchase it asks me to restart. And so on. Somewhere I may have a step wrong, but the key is supposed to be until October 2024 and we're still just in September. Any clues as what I have done wrong?
Re: Can't get Makemkv to run
#2 Post by Woodstock » Mon Sep 30, 2024 12:38 am
Do you have a disk in your drive while trying this? Your drive must be empty for the key to register, then you have to restart MakeMKV to make sure it was read.
robbo
#3 Post by robbo » Sun Oct 06, 2024 9:24 pm
Sorry for the late reply!
That was my issue. I did have a DVD in the drive.
Thank you so much for the answer.
Cheers!
