Makemkv on Win XP
specstuffer
Makemkv on Win XP
Post by specstuffer » Wed Sep 11, 2024 3:45 pm
The latest version of Makemkv will not work on Win XP. At least for me.
On startup I get an error message stating " The Makemkv conrol console had an error" I went back to version 1.15 whick does work.
Re: Makemkv on Win XP
Post by MartyMcNuts » Fri Sep 27, 2024 10:04 pm
And really why would it?? Why would any developer want to make their app compatible for an OS that support expired on essentially 20 years ago?
You really shouldn't be using xp. It is so unsecure and very unsafe to be using in 2024. Even win 7 or 8 should no longer be used.
Try upgrading to windows 10 or 11. Much more secure and better overall than XP ever was.
Ezatoka
Post by Ezatoka » Fri Sep 27, 2024 11:33 pm
to be fair, https://makemkv.com/download/ states:
MakeMKV 1.17.7 for Windows
Requires Windows XP or later, x86 or x64.
Post by Woodstock » Sat Sep 28, 2024 12:52 am
As stated, it's SUPPOSED to work on XP. And a number of us think Win10/11 are built to make XP look secure. :)
Not everyone can easily upgrade. There is a LOT of hardware out there that will be rejected by later versions of Windows. I could, in theory, upgrade this machine past Win7, but it would cause some significant compatibility problems. For example, my home camera systems require a version of Firefox prior to v57, which won't run on Win10 anymore.
As for the WinXP problem with MakeMKV, it kind of sounds like the issue may be with loading the key. Is the drive empty the first time you run MakeMKV? If not, try that, to see if it initializes and reads your key the first time. If it still complains about the control console, then we have to wait for Mike to respond. You might want to tag on to the MakeMKV 1.17.7 too old, crashes on start thread to get his attention.
