Playlist Order for Blue-ray "The Disco Van Dyke Show"
Fearless
Post by Fearless » Wed Mar 13, 2024 3:36 pm
As most of you are aware, getting the order correct for ripped Blu-ray tv shows is difficult.
But after finding the method describe here -- Reliable Way to Determine Episode Orde ... =6&t=20327" -- I believe I am on track to successfully ripping and ordering a collection of Blu-ray discs for "The Dick Van Dyke Show" (5 seasons).
I started with Season One, Disc 1, and created a spreadsheet to capture the data loaded in from the the disc into MakeMKV, and the result is below in a table. I will add more info on subsequent discs as I get them done.
Basically, the first set of .mpls files -- 00000.mpls thru 00011.mpls -- represent the show episode files, close to the correct order, which means you need to rename the ripped .mkv files for each appropriately, as E01-E11.
For example, this naming scheme should work to make the order correct:
  • t18.mkv becomes S01E01.mkv
  • t16.mkv becomes S01E02.mkv
  • t15.mkv becomes S01E03.mkv
..."and so on, and so forth, and what have you."... (who can guess that TV show reference?!)
EDIT - March 14, 2024:
1)  Added additional columns "EPISODE # / COMMENT" and "EPISODE TITLE".
2)  Also, I noticed that the sequence of playlist files in this first batch were not accurate, with a couple extra episode versions
    certainly throwing things off (the 2 versions with a commercial) and some other episodes out of order.  This batch really took
    reviewing each to make sure the episode #'s were assigned properly.
The Dick Van Dyke Show,  Season 1, Disc 1, Blu-Ray
MakeMKV-loaded Properties, Sorted on column PLAYLIST FILE — .mpls files first, then m2ts files.
SEASON		DISC	PLAYLIST FILE	VIDEO FILE	FILE SIZE	EPISODE # / COMMENT		EPISODE TITLE
Season 1	Disc 1	00000.mpls 	_t18.mkv	3.5 GB		E01				The Sick Boy and the Sitter
Season 1	Disc 1	00001.mpls 	_t16.mkv	3.6 GB		E10 with commercial		The Meershatz Pipe
Season 1	Disc 1	00002.mpls 	_t15.mkv	35.5 GB		E07				Jealousy!
Season 1	Disc 1	00003.mpls 	_t14.mkv	35.5 GB		E03				Sally and the Lab Technician
Season 1	Disc 1	00004.mpls 	_t12.mkv	35.5 GB		E04				Washington vs. the Bunny
Season 1	Disc 1	00005.mpls 	_t11.mkv	35.5 GB		E05				Oh How We Met the Night That We Danced
Season 1	Disc 1	00006.mpls 	_t10.mkv	35.5 GB		E09				The Unwelcome Houseguest
Season 1	Disc 1	00007.mpls 	_t08.mkv	3.5 GB		E06				Harrison B. Harding of Camp Crowder, MO
Season 1	Disc 1	00008.mpls 	_t06.mkv	3.5 GB		E02				My Blonde-Haired Brunette
Season 1	Disc 1	00009.mpls 	_t05.mkv	3.6 GB		E11 with commercial		Forty-Four Tickets
Season 1	Disc 1	00010.mpls 	_t03.mkv	3.5 GB		E10				The Meershatz Pipe
Season 1	Disc 1	00011.mpls 	_t02.mkv	3.5 GB		E11				Forty-Four Tickets
Season 1	Disc 1	00015.mpls 	_t04.mkv	382.0 MB
Season 1	Disc 1	00016.mpls 	_t01.mkv	76.2MB
Season 1	Disc 1	00017.mpls 	_t00.mkv	225.0 MB
Season 1	Disc 1	00018.mpls 	_t09.mkv	151.1 MB
Season 1	Disc 1	00019.mpls 	_t20.mkv	76.2 MB
Season 1	Disc 1	00020.mpls 	_t19.mkv	176.0 MB
Season 1	Disc 1	00021.mpls 	_t07.mkv	126.2 MB
Season 1	Disc 1	00022.mpls 	_t13.mkv	126.1 MB
Season 1	Disc 1	00025.mpls 	_t17.mkv	1.4 GB		Pilot (starring Rob Reiner)	Head Of The Family
Season 1	Disc 1	00002.m2ts 	_t30.mkv	31.3 MB
Season 1	Disc 1	00012.m2ts 	_t27.mkv	31.6 MB
Season 1	Disc 1	00014.m2ts 	_t24.mkv	24.9 MB
Season 1	Disc 1	00015.m2ts 	_t22.mkv	47.9 MB
Season 1	Disc 1	00016.m2ts 	_t21.mkv	3.9 MB
Season 1	Disc 1	00024.m2ts 	_t26.mkv	2.5 MB
Season 1	Disc 1	00049.m2ts 	_t25.mkv	191.0 MB
Season 1	Disc 1	00051.m2ts 	_t33.mkv	56.3 MB
Season 1	Disc 1	00053.m2ts 	_t32.mkv	113.3 MB	Extra (Reiner)
Season 1	Disc 1	00054.m2ts 	_t31.mkv	248.0 MB	Extra (Reiner, Leonard)
Season 1	Disc 1	00055.m2ts 	_t29.mkv	0.0 MB
Season 1	Disc 1	00057.m2ts 	_t28.mkv	0.0 MB		Extra (MTM, DVD, Reiner)
Season 1	Disc 1	00059.m2ts 	_t23.mkv	307.1 MB
douglsmith
Re: Playlist Order for Blue-ray "The Disco Van Dyke Show"
Post by douglsmith » Thu Sep 26, 2024 2:32 am
Thanks! That's really helpful even though it only works for some discs. Have you finished any other seasons?
In case anyone else is looking, the URL reliable way thread seems to be broken. It should be viewtopic.php?f=6&t=20327.
