But after finding the method describe here -- Reliable Way to Determine Episode Orde ... =6&t=20327" -- I believe I am on track to successfully ripping and ordering a collection of Blu-ray discs for "The Dick Van Dyke Show" (5 seasons).
I started with Season One, Disc 1, and created a spreadsheet to capture the data loaded in from the the disc into MakeMKV, and the result is below in a table. I will add more info on subsequent discs as I get them done.
Basically, the first set of .mpls files -- 00000.mpls thru 00011.mpls -- represent the show episode files, close to the correct order, which means you need to rename the ripped .mkv files for each appropriately, as E01-E11.
For example, this naming scheme should work to make the order correct:
- t18.mkv becomes S01E01.mkv
- t16.mkv becomes S01E02.mkv
- t15.mkv becomes S01E03.mkv
EDIT - March 14, 2024:
1) Added additional columns "EPISODE # / COMMENT" and "EPISODE TITLE".
2) Also, I noticed that the sequence of playlist files in this first batch were not accurate, with a couple extra episode versions
certainly throwing things off (the 2 versions with a commercial) and some other episodes out of order. This batch really took
reviewing each to make sure the episode #'s were assigned properly.
The Dick Van Dyke Show, Season 1, Disc 1, Blu-Ray
MakeMKV-loaded Properties, Sorted on column PLAYLIST FILE — .mpls files first, then m2ts files.
SEASON DISC PLAYLIST FILE VIDEO FILE FILE SIZE EPISODE # / COMMENT EPISODE TITLE
Season 1 Disc 1 00000.mpls _t18.mkv 3.5 GB E01 The Sick Boy and the Sitter
Season 1 Disc 1 00001.mpls _t16.mkv 3.6 GB E10 with commercial The Meershatz Pipe
Season 1 Disc 1 00002.mpls _t15.mkv 35.5 GB E07 Jealousy!
Season 1 Disc 1 00003.mpls _t14.mkv 35.5 GB E03 Sally and the Lab Technician
Season 1 Disc 1 00004.mpls _t12.mkv 35.5 GB E04 Washington vs. the Bunny
Season 1 Disc 1 00005.mpls _t11.mkv 35.5 GB E05 Oh How We Met the Night That We Danced
Season 1 Disc 1 00006.mpls _t10.mkv 35.5 GB E09 The Unwelcome Houseguest
Season 1 Disc 1 00007.mpls _t08.mkv 3.5 GB E06 Harrison B. Harding of Camp Crowder, MO
Season 1 Disc 1 00008.mpls _t06.mkv 3.5 GB E02 My Blonde-Haired Brunette
Season 1 Disc 1 00009.mpls _t05.mkv 3.6 GB E11 with commercial Forty-Four Tickets
Season 1 Disc 1 00010.mpls _t03.mkv 3.5 GB E10 The Meershatz Pipe
Season 1 Disc 1 00011.mpls _t02.mkv 3.5 GB E11 Forty-Four Tickets
Season 1 Disc 1 00015.mpls _t04.mkv 382.0 MB
Season 1 Disc 1 00016.mpls _t01.mkv 76.2MB
Season 1 Disc 1 00017.mpls _t00.mkv 225.0 MB
Season 1 Disc 1 00018.mpls _t09.mkv 151.1 MB
Season 1 Disc 1 00019.mpls _t20.mkv 76.2 MB
Season 1 Disc 1 00020.mpls _t19.mkv 176.0 MB
Season 1 Disc 1 00021.mpls _t07.mkv 126.2 MB
Season 1 Disc 1 00022.mpls _t13.mkv 126.1 MB
Season 1 Disc 1 00025.mpls _t17.mkv 1.4 GB Pilot (starring Rob Reiner) Head Of The Family
Season 1 Disc 1 00002.m2ts _t30.mkv 31.3 MB
Season 1 Disc 1 00012.m2ts _t27.mkv 31.6 MB
Season 1 Disc 1 00014.m2ts _t24.mkv 24.9 MB
Season 1 Disc 1 00015.m2ts _t22.mkv 47.9 MB
Season 1 Disc 1 00016.m2ts _t21.mkv 3.9 MB
Season 1 Disc 1 00024.m2ts _t26.mkv 2.5 MB
Season 1 Disc 1 00049.m2ts _t25.mkv 191.0 MB
Season 1 Disc 1 00051.m2ts _t33.mkv 56.3 MB
Season 1 Disc 1 00053.m2ts _t32.mkv 113.3 MB Extra (Reiner)
Season 1 Disc 1 00054.m2ts _t31.mkv 248.0 MB Extra (Reiner, Leonard)
Season 1 Disc 1 00055.m2ts _t29.mkv 0.0 MB
Season 1 Disc 1 00057.m2ts _t28.mkv 0.0 MB Extra (MTM, DVD, Reiner)
Season 1 Disc 1 00059.m2ts _t23.mkv 307.1 MB
