BDInfo feature?
LostBoy
BDInfo feature?
Post by LostBoy » Wed Sep 25, 2024 12:07 pm
Hey All,
When trying to find out the average bitrate for both audio and video on a 4K Bluray that I ripped with MakeMKV I was a little sad to see this data wasn't among the wealth of information in the app.
I ended up turning to BDinfo to get this, but it essentially re-reads the entire disc, taking another hour of time.
Is it possible to get this data from MakeMKV and I am just not looking properly, or do you think it could be added in a future beta?
An example from BDinfo is below;
DISC INFO:
Disc Title: Bad.Boys.Ride.or.Die.2024.UHD.BluRay.2160p.HEVC.Atmos.TrueHD7.1
Disc Size: 74,615,928,327 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9 (compatible layout created by DVDFab 12.0.5.1)
PLAYLIST REPORT:
Length: 1:55:58.951 (h:m:s.ms)
Total Bitrate: 84.61 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 66795 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 2093 kbps (3.04%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
AUDIO:
Codec Language Bitrate Description
Dolby TrueHD/Atmos Audio English 4944 kbps 7.1+11 objects / 48 kHz / 4304 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
DTS-HD Master Audio English 2228 kbps 5.1 / 48 kHz / 2228 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
DTS-HD Master Audio Italian 2233 kbps 5.1 / 48 kHz / 2233 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics English 35.498 kbps
Presentation Graphics English 41.763 kbps
Presentation Graphics Danish 28.305 kbps
Presentation Graphics Dutch 28.945 kbps
Presentation Graphics Estonian 30.199 kbps
Presentation Graphics Finnish 29.924 kbps
Presentation Graphics Italian 30.075 kbps
Presentation Graphics Latvian 30.828 kbps
Presentation Graphics Lithuanian 31.025 kbps
Presentation Graphics Norwegian 27.001 kbps
Presentation Graphics Swedish 28.268 kbps
Ezatoka
Re: BDInfo feature?
Post by Ezatoka » Wed Sep 25, 2024 2:39 pm
When you turn the movie into a MKV file wiht MakeMKV that file should contain the information, doesn't it?
Re: BDInfo feature?
Post by dcoke22 » Wed Sep 25, 2024 3:06 pm
Does mediainfo give you what you want from the .mkv files produced?
If not, you could use MakeMKV's backup function to make a decrypted backup of the disc first. MakeMKV can read the backup and create .mkv files from it at the speed of your storage which will be a lot faster than the speed of your optical drive. Perhaps BDInfo can operate on this backup as well?
Epitaph
Re: BDInfo feature?
Post by Epitaph » Tue Oct 01, 2024 3:52 pm
BDinfo will open a backup. I always backup to my pc first then open with Makemkv. I only use it on rare occasion, like when selecting individual tracks in Makemkv, I will also open the bluray in VLC and look at the runtime to determine the correct file. On occasion there will be multiple files with the same run time, opening bdinfo will let me see the stream/playlist which I can then play directly from the backups folders to find the correct one. The other issue I have had, albeit only once, was an "extra" makemkv was not listing.
